19888 turbo2 swap
Old Sep 16, 2008 | 12:04 PM
1.3_turbo's Avatar
Exclamation 19888 turbo2 swap
ok so i was driving my car home the other day and for some reason i cant rev past 2500-3000rpm no matter how far i push the gas down. it will just start shaking and bog. but it will stay running. so it cant be a plug? i was thinking to check the coil packs.. i do notice some oil smoke coming near my turbo. could this be the problem. because i know if i have a boost leak the car wont even run for some reason? is that all turbo'd rx7's? any assistance here would be greatly appreciated im stooped on this one
Old Mar 28, 2010 | 11:33 PM
xxnickpxx's Avatar
having a similar issue with my newly turbo II swapped gxl. from what i have read it could be many things. try the search button. and search the FAQ. it might help with your problem.
Old Mar 29, 2010 | 11:48 PM
Brodie121's Avatar
what ecu?
Old Mar 31, 2010 | 12:21 AM
xxnickpxx's Avatar
i have both n332 and rtek 1.7 n332. same problem with either. I'm going to test the injector wires tomorrow. the car did have rodent droppings in the engine bay when i bought it. i did inspect the harness thoroughly before installing, but better to double check before i get more serious. ive seen many posts on this but never really the same solution.
Old Mar 31, 2010 | 02:34 PM
RotaryRocket88's Avatar
Top Down, Boost Up
To both of you...
What emissions wiring harness was used (original NA or TII), and are both engines S4? Hopefully everything is S4 TII including the ECU (N332/333), boost sensor (N318) & AFM (N318).
If you want to check all of the injectors for power, remove the panel covering the ECU. On the smallest plug there are 4 light green wires (LG, LG/W, LG/R, LG/B). Each of these should have 12V if the key is 'ON' or the engine is running. The S4 FSM has a breakdown of all ECU pins and testing procedures in the Fuel and Emissions section. You can test other components like the boost sensor while in the area.
Old Mar 31, 2010 | 06:19 PM
Kaane's Avatar
Sounds like a AFM issue. I would check the harness and test the part out.
Old Apr 1, 2010 | 11:09 AM
xxnickpxx's Avatar
my harness is the N/A harness. the motor is also s4. ill be able to get to the car later today after work. so ill pick up an ohms meter on my way home and test all the sensors. im still going to take my uim off and clean up the grounds and check the injector wires again. as a side note i have all my emissions removed. i do have 720cc injectors that are supposed to be drop in, but when they wouldn't come online i put the stock back in to see if they were in fact high impotence. but no change. so, on to testing. ill get back to you guys, thanks for the help so far.
Cuzzynz
141
May 28, 2020 09:23 AM
freddyrx3
Rotary Drag Racing
31
Mar 9, 2019 08:32 PM
Wehavetocook
Sep 23, 2015 11:04 PM
