did i screw up oil control rings?!
Old Sep 15, 2008 | 04:23 PM
AlexG13B's Avatar
brap brap brap
Unhappy did i screw up oil control rings?!
ok i removed all emission etc.
i was running a catch can (comes enclosed non vented)
ran one hose from oil filler neck and the other from the intermediate plate vent, both to catch can.
drove 1k miles what way with no boost (rebuilt motor)
now i drill a hole on the can and put in a filter so it can vent out the pressure and i also changed the oil.
i started up the car and noticed it was smoking, its never smoked before. made a small cloud which has to be oil cuz i dont dont fuel smoke moves away from the car that far before it goes away.
i started to rev it till like 3k rpms to see if it will clear up and it seems like it has alil.
did i screw anything up? or is this just cuz i vented the catch can?
Old Sep 15, 2008 | 04:47 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
well the few times my oil fill vent came off it did smoke a some, i generaly didnt notice because i just routed it though my intake
hows the engine vacume, oil have gas in it? if both are fine id say ur oil control rings are probably fine
Old Sep 15, 2008 | 05:03 PM
AlexG13B's Avatar
brap brap brap
maybe it has something to do with not using a check valve?
idk its weird that now all of a sudden its vented and it smokes, it was the frst startup since venting it.
FD7KiD
15
Feb 26, 2021 10:12 PM
rxmiles
Aug 24, 2015 02:07 PM
