Power FC inj. drivers in PFC?
Old Sep 15, 2008 | 12:54 AM
sk8world's Avatar
Chasing numbers
Can these go bad but still fire? Can they just be firing partial? I was having issues on a new motor fired up on 1 rotor then the other started running. I did change the inj. clips and re crimp/solder the wires from harness before firing. I am pretty sure I have a short there but was going to add the FJO inj. driver and get rid of the resisters. Just wanted to know about the drivers before hand as i have a AEM I can try out to see if I like it and I believe it runs both high and low impd. inj's.
Old Sep 22, 2008 | 07:54 PM
mono4lamar's Avatar
In the burnout box...
Sometimes the pins in the American style connectors back out or cause an interminute connection. Try taking a stethoscope to hear if the injector is firing. You can also use a multimeter and just look for any type of jump. Maybe it's dead, maybe its stuck... Good luck!
Old Sep 23, 2008 | 12:44 AM
Dudemaaanownsanrx7's Avatar
wannaspeed.com
How do you know its the injectors? It could be spark issues. Coils, wires, plugs. Or one rotar could have been flooded at first.
Old Sep 23, 2008 | 12:50 AM
wannaspeed.com
How do you know its the injectors? It could be spark issues. Coils, wires, plugs. Or one rotar could have been flooded at first. This happened to me once when i was working out some issues. I unflooded it by speeding the engine up with that injector unplugged. Though i actually doubt this is your problem cause weird stuff like that tends to happen to mainly just me haha
Old Sep 24, 2008 | 12:22 AM
sk8world's Avatar
Chasing numbers
confirmed bad inj. wiring. Now trying to resolve high knock readings and ignition brake up with very low loads. This is killing me. I would have rather spent another month on the rebuild than this trouble shooting. Had no issues before on last motor and have goin over any changes to no avail..
RE-Mamamia
Sep 11, 2015 02:13 PM
