What Tires do you use?
Old Sep 15, 2008 | 12:47 AM
illusion38's Avatar
Well I would be amazed if no one has done this yet. But searched and it was a swing and a miss. What kinda rubber are you daily drivers driving around on.
Trying to find a good street tire to use, what are your favorites?
Old Sep 15, 2008 | 03:53 AM
Ceylon's Avatar
Non Runner
Toyo Proxes R888
Front =255/35 r18 @ 29psi
Rear =265/35 r18 @ 27psi
Works for me.
Old Sep 15, 2008 | 05:03 AM
dgeesaman's Avatar
^ Not a street tire. The R888 can be driven on the street but it won't last long or perform safely in the cold.
Are you looking for all-season tires? Is budget a factor? How long do you expect them to last?
Dave
Old Sep 15, 2008 | 05:24 AM
Kentetsu's Avatar
For the cheap side, I've been using Sumitomo HTR 200 for a couple of years now. 50 bucks each, and they perform fairly well.
Old Sep 15, 2008 | 05:49 AM
Ceylon's Avatar
Non Runner
Toyo Proxies T1-Rs are pretty good for the road from what I've seen, they are about mid-range in pricing. I've used them on my road rims for the last 6 months or so.
Old Sep 15, 2008 | 10:07 AM
s1mpsons's Avatar
HamfistRacing.com
I run Toyo R888 245/45/16.
Old Sep 15, 2008 | 10:18 AM
burtoncr's Avatar
Either Falken RT615s (summer tire) or ST115 (more year round). Discount tire bought the mold for the ST115 so they are available again.
Old Sep 15, 2008 | 11:02 AM
Mahjik's Avatar
Mr. Links
For a good daily driven street tire, check out the Goodyear Eagle F1 GS-D3. Great tire for dry and wet driving. Also, the Toyo Proxes T1r are a good tire. If you want something a little more aggressive for the street (with the sacrifice of wet performance) take a look at the Falken Azenis RT615. I'm currently using the Nitto Invo's on my M3. They aren't bad, but they aren't great either.
Old Sep 15, 2008 | 11:24 AM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
Bridgestone Potenza RE01R is what I run.
Old Sep 15, 2008 | 12:43 PM
purerx7's Avatar
Registered User
I have tried A LOT OF brands in tires, mostly because i like to switch wheels every 6 months. The toyo t1r is the best tire for the money. Spend a bit more and get the Michelin pilot ps2, by far the BEST street tire you can run. It was quite, smooth, great tread-wear and was great in the rain. Only downside is they are quite expensive, but you get what you pay for.
Old Sep 15, 2008 | 06:36 PM
illusion38's Avatar
Thanks for the input, yeah looking for summer use only. Looking through a couple options and came across these, it looks well rated. Anyone have experience?
http://www.1010tires.com/tire.asp?ti...SPT+%28KU31%29
Thanks
Old Sep 15, 2008 | 07:46 PM
Mahjik's Avatar
Mr. Links
If they have your size, I would recommend Kumho Ecsta MX over those.
Old Sep 15, 2008 | 09:23 PM
dgeesaman's Avatar
For a true summer tire, I've been thoroughly pleased with Goodyear Eagle F1 GS-D3s and Bridgestone RE-01R's. I've also heard good things about the Ecsta MX, Falken RT-615. I autocrossed in an MX-5 with Michelin Pilot Sport PS2s - we wailed on that car for 2 hours straight (probably 25 runs at 35 sec each) and those tires just refused to overheat and lose grip. That's another excellent tire.
Old Sep 15, 2008 | 09:46 PM
juicyjosh's Avatar
Seismic Disturbance
Advan Neova AD07 235/40-18 and 265/35-18
*Very grippy*
**once they're broken in**
When I first put them on, my touring FD had what I refer to as "Cadillac-" or "pinky-steering."
These tires should be broken in *immediately* with no one around i.e. hard left-and right turning, braking.
Actually, I'll change that "should" into a "MUST."
With the Neovas I get so much grip in sweepers, I'm holding onto the steering wheel to keep from sliding onto the center console or onto my door. In "grip" driving, I haven't actually slid sideways yet, which really says a lot about these tires, because I DO drive pretty fast in the turns - ONLY ON A TRACK, of course... In drifting, they break very predictably and regain grip quickly and fairly smoothly. Wear is surprisingly good, too. I'm running TEIN Flex on stock bars, 1.2* negative all the way around.
Hopefully, this is valuable feedback for people considering the Neovas.
Josh
Old Sep 15, 2008 | 10:26 PM
KinRx7's Avatar
another one for toyo t1r's
fantastic street tyre
Old Sep 15, 2008 | 10:29 PM
illusion38's Avatar
http://www.1010tires.com/tiresearch.asp?submit=yes Those are the two Kumho Tires, why would you suggest the MX over the SPT. Just curious.
Old Sep 16, 2008 | 05:07 AM
dgeesaman's Avatar
I have SPT's. I'm not impressed with them and I've never heard anything great about them either.
dave
Old Sep 16, 2008 | 09:19 AM
Mahjik's Avatar
Mr. Links
I've had some friends try them and went back to the MX. For the price, the MX is still a good tire even in it's old age. Their new replacement for the MX titled the XS is now available. However, since it basically just came out a week or two ago, its in very limited sizes.
Old Sep 16, 2008 | 10:06 AM
mrb63083's Avatar
Falken ZE912's 255/40/17 wrapped on Enkei RPF1 17X9's all around (+45)
Old Sep 16, 2008 | 01:05 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
ive been through 2 sets of michelin pilot sport 2s and they wear a bit fast and tend to get hard after a year or so. they dont seem to heat cycle well
Old Sep 16, 2008 | 03:12 PM
Red95FD's Avatar
red89fc
GoodYear Eagle F1 GS-D3 right now. Next week I get new wheels, 17 inch 5zigin FNO1RCs, with Dunlop Star Spec 255/40/17 all the way around.
Old Sep 17, 2008 | 12:37 AM
rxspeed7's Avatar
F-IT
falken azenis rt615 ftw
235/40/17
255/40/17
Old Sep 17, 2008 | 01:59 AM
666cody666's Avatar
Got the toyo T1R and love them way better then the yoko es100s i had. made the car more better in the rain also
Old Sep 17, 2008 | 11:11 AM
Highwind's Avatar
Engage
Does anyone have any opinions on Falken FK-452's? It's supposedly meant for "luxury-performance" type cars, but I was curious if anyone here put it on an RX7.
Old Sep 17, 2008 | 05:21 PM
Ceylon's Avatar
Non Runner
My bad! They are R1-R tyres.
