Buying a 79 500 km Engine. Wondering if im doing the right thing?
Old Sep 14, 2008 | 02:37 PM
OutCold's Avatar
If i buy a 79500 km Turbo 2 engine, does it need an overhaul? Thing is i got an engine in the car already wich will go back too normal if i overhaul it, should i still opt too buy a lower mileage engine and do the overhaul on that one instead?
Or simply screw the overhaul on the new one and sell the old one?
Im having it dissasembled and streeported aswell as putting in more heavy duty Apex Seals ( at least that was my plan ) but i dont really wanna give the engine a total overhaul if its not gonna be needed in a while...a total overhaul here will cost me about
Whats your opinion on this? The cheapest option for overhaulin here in Norway will be about a whooping 4.000,-
Old Sep 14, 2008 | 02:49 PM
Turbo II Rotor's Avatar
Who Shot the Sheriff?
Test compression and if the numbers look good just swap it in. Also most people will say to avoid "heavy duty apex seals" and just go with Mazda seals.
Old Sep 14, 2008 | 02:50 PM
Boosted11's Avatar
Pistons are gay
It's really hard to say, mostly depends on the abuse it took. If it was treated good, then **** that motor is nearly brand new. Don't forget there really isn't any way for the seller to prove it truly is 79,500km's.
Old Sep 14, 2008 | 02:58 PM
OutCold's Avatar
So the Mazda Seals can handle about 450-500 hp?
Old Sep 14, 2008 | 03:03 PM
Hp doesn't break seals, detonation does.
Old Sep 14, 2008 | 03:18 PM
OutCold's Avatar
Aha i see, Should i have the guy selling it have it compression tested while its still in his car? Or can it be done even tho the engine is taken out?
Old Sep 14, 2008 | 03:25 PM
dot_txt's Avatar
My car hates me
Still in the car. Its possible with it taken out but a pain in the A**
Old Sep 14, 2008 | 04:29 PM
misterstyx69's Avatar
Retired Moderator, RIP
I would be there,IF the guy is going to do a Compression Check.So Many People have Bullshitted about the Engines they have when they sell them..saying it's got 130 compression,blah blah(when it's junk)..If the guy is local,go see him perform the test.Just to make sure the numbers are OK.If not,search for another engine,or rebuild this one..Or Whatever...another thing,If the compression is fine,Install the darn thing.Enjoy it,until the compression Fades and it becomes rebuild time.
Old Sep 14, 2008 | 04:45 PM
OutCold's Avatar
Previous owner of the car is a buddy, he can clear the fact that it had just under 79k km when he sold it so im pretty sure that info is correct, Pic of the engine:
Its not like i put that dumbass arrow there cause i didnt think u knew where the engine was, its just too point out its only the engine basic including the intercooler ill be getting. (excl. Water pump,dynamo,PS blablabla)
Old Sep 15, 2008 | 03:07 AM
OutCold's Avatar
Looking arund im thinking: " What if i bought the parts he needs/wants too replace myself, it would be hella cheap and as long as the engine is coming apart for streetporting why not just change it all? Im guessing this is one of the things i need too get for him : http://www.mazdatrix.com/getprice.asp?p ... -2710-8DF6 ? Are there more parts i need for an overhaul?
Old Sep 15, 2008 | 06:00 AM
OutCold's Avatar
Fixed link: http://www.mazdatrix.com/b2.htm
God i wish i could edit my own posts...
alphawolff
Nov 17, 2015 05:57 PM
plentymoon
NW RX-7 Forum
Sep 5, 2015 08:55 AM
Engine stand ready
Aug 14, 2015 10:26 PM
