injector connectors..which one where?
Old Sep 14, 2008 | 01:41 AM
MDD0101's Avatar
slowmotion
Unhappy injector connectors..which one where?
ive searched..and still am searching at the moment. can someone just fill me in.. right now i have it hooked up like so: theres a long and a short length part of the harness thats split up like the pic i made.. the left side has the clip for the water pump thermo sensor(green) on it also so i know thats in the right place and i showed it as reference. since i know the thermo sensor is in the right place i know the short length injector clip on that side of the harness has to be to the left injector on the primary rail.. am i right with the rest of them?
Old Sep 14, 2008 | 01:47 AM
MDD0101's Avatar
slowmotion
"Primary has shorter leads; secondaries are longer.&nbsp The "bundle" is grouped for front or rear rotor.&nbsp I believe the front rotor bundle also has the plug for the water thermo sensor?&nbsp The rear bundle has two extra leads for those stupid bypass solenoids on the upper intake manifold for a turbo engine."
just came across this..if this is true then the way i set it up is correct?
Old Sep 14, 2008 | 02:01 AM
rowtareh?'s Avatar
I Dislike Everything
You're missing a front plate.
Old Sep 14, 2008 | 02:07 AM
MDD0101's Avatar
slowmotion
you are right. haha what about my injectors!?!
Old Sep 14, 2008 | 04:54 AM
RETed's Avatar
Pic is right.
Branches with the water thermo sensor is for the front rotor.
You almost cannot mix primary versus secondary.
The rear rotor injectors has the two extra plugs for the stupid solenoid valves on the back part of the intake manifolds.
-Ted
Old Sep 14, 2008 | 08:48 AM
HAILERS's Avatar
HAILERS
Look at the wiring diagrams. The wires area color coded. Like one wire on each connector is, light green/black, light green/white, light green, light green/red etc. And the other wire at each connector is the power wire and is black/yellow. Free wiring diagrams downloadable from this site. See FAQ
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
connerfd3s
Sep 19, 2015 05:58 PM
