turn signal problem
Old Sep 12, 2008 | 06:17 PM
87 t-66's Avatar
not a drifter
turn signal problem
whenever i put on my headlights both my turn signals come on as well as the 2 turn signal indicators in my instrument cluster. also, if i flip the turn signal switch to either side, both sides light up as well as both the lights in the cluster.
i dont know if this has anything to do with it or not...
i am using the jdm turn signals with only 2 wires instead of 3 that the usdm models have. i soldered the red and green wires together and ran them to 1 black wire on the jdm signal, and ran the black wire to the 2nd black wire on the signal. when i connected just the red and black wires to test them at first, the lights didnt come on at all until the green wire was connected.
Old Sep 12, 2008 | 09:53 PM
Icemark's Avatar
yep, that is your problem. Can't join the green and red wires. One is turn signal, one is parking lights
You need to change it back to 3 wire or wire up the second bulb (in the small light) to the red/black while the green goes to the main turn bulb in the larger section
Old Sep 12, 2008 | 09:55 PM
87 t-66's Avatar
not a drifter
there is only 1 bulb in the turn signal and only 2 wires coming off the back.
what do you mean by "parking lights"? when do they come on?
Old Sep 12, 2008 | 10:08 PM
87 t-66's Avatar
not a drifter
can i run the extra wire to the jdm ftps and use them as parking lights?
Old Sep 12, 2008 | 10:50 PM
BrettLinton7's Avatar
Lots of rotors
I think he means that the red goes to the running/ parking lights that only light up when the headlight **** is turned either 1 click or 2. The green light goes to the other half of the bulb that blinks... Are you using the 1156 bulbs with 2 lights in the bulbs or the ones that are like the reverse/ tag lights that only have one light in the bulbs?
When you joined the red/green wires you're connecting the running lights to the blinkers. The same thing happend in my moms accord when the bottom of the bulbs got corroded and the 2 lights linked together...
Last edited by BrettLinton7; Sep 12, 2008 at 10:52 PM. Reason: I hope that doesn't sound retarted... I need better descriptions
Old Sep 12, 2008 | 11:06 PM
87 t-66's Avatar
not a drifter
i am using the bulbs that came with the lights...i guess ill try to wire the ftps up as parking lights using the 3rd wire.
Old Sep 21, 2008 | 09:10 PM
87 t-66's Avatar
not a drifter
ok so i removed the red wire and now the turn signals in the front bumper act as they should...but now they dont work in the rear
Old Sep 24, 2008 | 09:04 PM
87 t-66's Avatar
not a drifter
so if the front turn signals come on using the switch but the rears dont...and the rears come on when using the hazards, its gotta be the switch right?
ZacMan
Sep 19, 2015 09:20 PM
vmerino
Sep 5, 2015 11:26 AM
