starter issues
Old Sep 11, 2008 | 05:38 PM
island-fc's Avatar
starter issues
-so i bench tested my starter, it works, but when i put it in the car it doesent,
-i have 12v at the solenoid wire key one cranking position
-and i have 12v at the power wire
-and there is continuity from the neg side of the battery to the started
-it goes through phases of working then not working
Old Sep 11, 2008 | 05:59 PM
Hazard15301's Avatar
Rotor Junkie
Ignition switch might be bad.
Old Sep 11, 2008 | 06:00 PM
NinjaGUYdan's Avatar
Jelly McFish
Could be bad starter solenoid, dirty ignition switch, bad connections not transferring current.
Old Sep 11, 2008 | 06:29 PM
island-fc's Avatar
if it was a bad ignition switch, why would i get 12volts at the solenoid in the key cranking position
and i tested the starter + the solenoid it all works
Monsterbox
Sep 11, 2015 03:29 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
