help please
Old Sep 11, 2008 | 12:10 PM
b almer's Avatar
help please
i just turboed my na motor and got it started and idling but when i give it gas it only revs to 2k and then falls flat on it face
Old Sep 11, 2008 | 12:16 PM
misterstyx69's Avatar
Retired Moderator, RIP
vacuum leak.
Old Sep 11, 2008 | 12:21 PM
katkaroto's Avatar
dewey
can you send me pics on how you turbo'ed your na.
Old Sep 11, 2008 | 12:25 PM
b almer's Avatar
i found a small vacuum leak and fixed it on one of the block of plates by spraying carb cleaner were i thought it was leaking but then but have found any other ones
Old Sep 11, 2008 | 12:27 PM
b almer's Avatar
yeah i can send you pic when i get off work
Old Sep 11, 2008 | 12:50 PM
katkaroto's Avatar
dewey
good diagnosis
Old Sep 11, 2008 | 01:24 PM
Texas_Ace's Avatar
so it is working now?
And yes, PICS!
The more the better!
Old Sep 11, 2008 | 02:33 PM
b almer's Avatar
i fixed the one vacuum leak and havent found any other one and it still doing the same thing
Old Sep 12, 2008 | 01:39 PM
b almer's Avatar
here are the pics of the turbo set up
the black flexible pipe on the intake side is just so i can get the car running the guy welding the piping went on vacation for 2 week and didnt finish it so it the only thing i could think of for the time being
my buddy welding the piping removed the air intake temp senser would that do that
no vacuum leaks now just wasted ahole can of carb cleaner trying to find the smallest leak
Old Sep 12, 2008 | 01:50 PM
2-N-D-pink's Avatar
rx7parts
your map sensor, air flow meter, injectors (unless you upgraded) and ECU is for a TII....correct?
Old Sep 12, 2008 | 01:52 PM
b almer's Avatar
no it is stock na injectors for the primary and T2 for secondary and na maf and na ecu
Old Sep 12, 2008 | 01:54 PM
Texas_Ace's Avatar
Well the NA ECU could be part/all of your problem. it doesn't know what to do with boost and seeing as it falls flat right about the itme the turbo starts to spool it makes me think that might be it.
Old Sep 12, 2008 | 01:58 PM
Houstonderk's Avatar
My girl
Yea don't see how its going to work with the n/a electronics.
Old Sep 12, 2008 | 02:00 PM
b almer's Avatar
i have a T2 ecu for a S5 and my car is S4 so that is why the na ecu is in
i didnt know that ecu was for a S5 and the guy i bought it from didnt tell me
Old Sep 12, 2008 | 02:01 PM
My girl
You got the harness also? Going to have to rewire some stuff.
Old Sep 12, 2008 | 02:03 PM
b almer's Avatar
no i dont have the wiring harness
if i find a S4 t2 ecu would that work
Old Sep 12, 2008 | 02:11 PM
My girl
Part of the problem. THere is a writeup somewhere about all to change. afm, pressure sensor, etc.
Old Sep 12, 2008 | 02:14 PM
b almer's Avatar
ok thanks
Old Sep 12, 2008 | 02:20 PM
2-N-D-pink's Avatar
rx7parts
yeah....as soon as you said N/A turbo break up problem, I knew it had to be electronic some where.
I think the S4 TII ECU will work as long as you have S4 AFM and map. And you still dont have enough injector by the way. I was getting 13.4 Air Fuel ratios with the stock turbo and injectors. (no emissions at all and 3" DP - exhaust)
Old Sep 12, 2008 | 02:37 PM
b almer's Avatar
if i wiring in the T2 550 would that be enough for it
Old Sep 12, 2008 | 06:23 PM
2-N-D-pink's Avatar
rx7parts
If you wiring in?
If you have all 4 injectors itll be enough. Keep in mind that if you have an catless exhaust and 3 inch down pipe, your WILL over boost. It happends to me all the time (which is why I was reading 13.4 air fuel ratio) but if you dont over boost it should be enough too keep it safe.
But I can almost guarantee YOU WILL over boost. So instead of buying another set of stock 550cc injectors, just go head and upgrade. And port the wastegate some.
Old Sep 12, 2008 | 06:27 PM
2-N-D-pink's Avatar
rx7parts
I didnt even notice that you have a V-mount....post more pics dude what are you doing!!?!!
Old Sep 13, 2008 | 02:34 AM
b almer's Avatar
i all ready had the set of 550 injectors and the reason i had that problem i found out was the way the maf was position
i will have the pics of the vmount up tomorrow cause i will have everything back together
