weird temp problem?
Old Sep 9, 2008 | 06:11 PM
a2dadamm's Avatar
weird temp problem?
hey guys whats up?
okay so on my stock 89 gxl i have this issue. it runs and drives fine but if i corner hard or eccelerate hard my temp gauge goes crazy, it will shoot all the way up as high as it can go then bounce down to normal and back and forth for about a minute or so, just keeps bouncing around crazy, but while it's up at the highest position way above H if i give it gas it will go down and when i let off it will rise back up. and nothing is gradual it's all very vast instant changes and then sometimes it will just go back to normal for a few miles and then goes bizerk again. lol . it doesent over heat at all coolant isnt boiling either
any ideas?
ive flushed the rad with prestone flush, coolant was nasty, then put all new coolant hoping it waould help but nada.
any help would be appreciated
Old Sep 9, 2008 | 08:50 PM
clokker's Avatar
Cake or Death?
Check the wire that connects to the temp sending unit on the engine.
Since the coolant can't behave as you've described, the problem must be with the gauge/sending unit/wiring.
Most likely, the wire to the sending unit is frayed somewhere and making intermittent ground- which would cause the gauge to behave like yours is.
Old Sep 9, 2008 | 09:54 PM
a2dadamm's Avatar
thanks,
and since im a learning noob could someone explain to me where those wires are located?
someone also mentioned it could be the tempeture switch
im not quite sure what or where that is to check it?
all help is greatly appreciated
The1Sun
Sep 15, 2015 04:45 PM
sherff
Sep 12, 2015 12:22 PM
vmerino
Sep 5, 2015 11:26 AM
