Introduce yourself New members post about yourself here...
new in CT, wanted to add following
Old Sep 8, 2008 | 11:30 PM
gonetomorrow's Avatar
Jus passin through
NA 1988 fc3. I've followed the pages of the owners manual for engine removal and have also removed the hood. The owners manual doesn't provide lift point locations for attaching the chain. It also says to remove the bolts attaching the tranny to the motor but I'm unsure how to break the connection between the two. I may pull the tranny as well (car not running when purchased and lower tranny drain plug missing in action) but figure it will be easier to do the pieces separately. I searched, particularly for pictures and looked at the faqs but didn't have any luck. Any pics, links or advice will be much appreciated
I must be two tired to figure out how to get five posts.
Old Sep 9, 2008 | 07:13 AM
autoappearance's Avatar
Auto Appearance
I also am in the process of yanking out a rotary that is a no go.
And the trans which will be replaced due to the no go rotary.
I am lifting the trans and engine out together.
Unconnected all the wiring, linkage, engine mounts, tranny crossmember, driveshaft.
I hooked to the rear of the engine on a hook that is already there, then I pulled the 2 alternator bolts out, got 2-3" long grade 8 bolts, same size, and hooked to them both.
I am using a chainfall for this, not the cherry picker.
PS - mine is getting a 350/350 combo
Old Sep 9, 2008 | 08:05 AM
240sx2jz's Avatar
Newbie
where abouts in ct are ya?
Old Sep 9, 2008 | 08:07 AM
240sx2jz's Avatar
Newbie
sometimes its also easier to drop the motor/trans out the bottom of the car and leave it connected to the crossmember, drop it on a dolley and roll it out.
just a thought
Old Sep 9, 2008 | 08:10 AM
Hitokiri_Gensai's Avatar
RHD ftw!
yeah where in CT are you?
Old Sep 9, 2008 | 09:56 AM
Milkfish636's Avatar
lift brackets is in front of the engine and the back. Remove all the bolts you see that connect engine to tranny. Remove engine mount bolts. Support the tranny. i used a stackup of bricks and 2x4's. Lift engine up just a touch and give it a tug by the chains. You'll feel it start to break loose. If you do decide to take out tranny also, remove shifter, driveshaft, disconnect speedo cable, backup sensor, neutral switch sensor, disconnect crossmember and then you can pull it all out.
Four more posts
Old Sep 9, 2008 | 11:36 AM
Jus passin through
I'm also using a chain suspended from a garage ceilingn and a 3000 pound comealong to do the lifting. I was thinking about doing both together but then I'd better put those tranny bolts back in. I saw the hook in the back of the motor, good choice. I'll also look at the alt bolt holes. Not going to go 350, yet.
Old Sep 9, 2008 | 11:38 AM
Jus passin through
Down state. I saw there was a parts swap/gtg in bpt recently that I wanted to go to but couldn't make. Just wanted to look around. Too new to mazda to have anything to swap or know what I need to pick up.
Old Sep 9, 2008 | 11:44 AM
Jus passin through
just a thought
Seen this done with honda's but don't know about the rx7. For one thing, I've been using the crossmember as a floor jack point. Not exactly sure how i'd lift it though I suppose I could do one frame rail then the other. I could pick the whole front of the car up with the comealong if I had a secure spot. Thinking stearing rack but wouldn't want to bend anything, though I may be replacing it anyway. Is this a preferred way to get it out?
Old Sep 9, 2008 | 11:48 AM
Jus passin through
Fairfield county. I'd be more specific but I have "my car was stolen from my drivewayitis." Nothing personal and not that I think anyone is going to steal my rolling shell, lol. And, it's not a honda.
I'm digging the car in your avitar.
Old Sep 9, 2008 | 11:51 AM
Jus passin through
Four more posts
Thanks, I'll look but do you have a general location for the bracket in the front? The one in the back seems pretty clear.
Also, I've only removed the brackets on the bottom of the tranny. I'm thinking I'll have to remove the intake manny to get a better shot at the ones on the top.
Old Sep 9, 2008 | 11:54 AM
Lil Red Resurected From Dead's Avatar
Rotary Parking Only
Hey guys check us out on the web Vintagemazda.com we are locally based out of CT Mainly Fairfield County and can help with any of your rotary needs well mostly old school but a 7 is pretty much a 7. By the way we are the ones that hosted that parts / swap meet you are speaking of.
Last edited by Lil Red Resurected From Dead; Sep 9, 2008 at 11:55 AM. Reason: Forgot.
Old Sep 10, 2008 | 11:10 AM
Auto Appearance
there are 3 bolts on the passenger side under the car
and 1 nut on the drivers side
Old Sep 10, 2008 | 12:51 PM
Jus passin through
This is for the tranny to engine? The nut on the driver's side is the starter motor, I believe. I took one of the bolts out on the pass side and am guessing the other two are on the top of the housing. I think I might take the intake manny off for ease of access.
Old Sep 11, 2008 | 02:55 PM
240sx2jz's Avatar
Newbie
i put my motor and trans in by dropping the car down ontop of it, its the only it would have worked (2jz with a v161 isnt too small) it rubbed on the frame rails gettin it in there too she's pretty shoe horned. i used an engine hoist to lift the front of the car up froma couple different points and it worked out really well...
Old Sep 11, 2008 | 03:25 PM
quinthawk's Avatar
welcome
Old Sep 12, 2008 | 02:13 PM
Jus passin through
Old Sep 12, 2008 | 07:36 PM
RHD ftw!
heh yeah i hear you on that... thankfully my car is lacking an interior so itd be hard to steal at the moment... although im nearing completetion so the fear of vandals or theives comes back.
if you need any help tho give me a shout, im in Simsbury CT, up near the MA border.
thanks, thats my baby in that avatar... although to be totally honest... shes a whiny baby with a big appetite and always needs to see the doctor (mechanic) so im thinking of trading her away for a US legal Skyline...
dkwasherexd
May 27, 2017 04:51 AM
