transmission help
Old Sep 8, 2008 | 12:42 PM
iani1.1's Avatar
DILLIGAF
transmission help
anyone know the easiest way to remove the 5th bolt on the tranny? im talking about the one behind the intake manifold, such a pain in the ***
Old Sep 8, 2008 | 01:30 PM
Turbonut's Avatar
It's been years since I've done mine, but don't remember any problem. With a jack under the engine and trans mount out, lower the engine to get better access.
Here's a couple:
https://www.rx7club.com/showthread.p...n+bolt+removal
Old Sep 8, 2008 | 03:49 PM
iani1.1's Avatar
DILLIGAF
cool those were helpful thanks, no gotta figure out how to keep the flywheel from spinning so i can take the clutch and flywheel out
Old Sep 8, 2008 | 07:02 PM
Turbonut's Avatar
Removing the PP shouldn't be a problem, but the flywheel:
One choice:
All non-turbo flywheels:
49-220NT $22.89
Does NOT Fit Automatic
Another:
http://www.rotaryresurrection.com/2n...el_remove.html
Old Sep 8, 2008 | 11:34 PM
89GXLer's Avatar
If you're careful, you can use an air chisel against one corner of the nut (in the loosening direction of course) and it will loosen.
I did this with mine and it came off very easy only leaving a light mark on the nut. A little rub on the bench grinder and the mark was gone.
Another option that I used to torque the nut to 300+ pounds was to chain the flywheel to the block - this was suggested by a retired large equipment mechanic who happened to be there at the time and he said he used to do that kind of thing all the time.
Just make sure your bolt in the flywheel has plenty of thread into it to make sure it doesn't break, bend, or tear thread out.
Did the trick for me.
As for the 5th bolt on the tranny, I just squeezed in with a box end wrench to break it loose and then used a ratchet box end to spin it out.
Grant
Old Sep 9, 2008 | 01:04 AM
Ex-Eg-Driver's Avatar
RX-7 DISCIPLE
Flywheel stop tool from MAZDATRIX works.
Make sure to replace the Rear Main Seal while you have the flywheel out, and also dont lose the flywheel KEY!
MILOS7
Oct 9, 2015 02:19 AM
rxlevi7
Sep 26, 2015 07:28 AM
