glowing RB headers
Old Sep 8, 2008 | 12:38 AM
kiddofspeed's Avatar
berlinetta
glowing RB headers
anyone ever have a problem with high idle, and glowing headers after emissions removal??
i've blocked off everything and hooked the oil vaccumm back up don't know where to start.
Old Sep 8, 2008 | 01:40 AM
w00t's Avatar
Do you know your A/F's or EGTs?
Old Sep 8, 2008 | 07:20 AM
Black Knight RX7 FC3S's Avatar
Turbo power, activate!
wait....your rbheaders are glowing at idle?
As wOOT said, check your A/F and the EGT.
Is the idle steady, or is it hard to startup?
Check your hose to the boost sensor, its on the passenger side next to the air meter.
Old Sep 8, 2008 | 10:33 AM
SDrotary-FC's Avatar
@ pipnorcali
they are going to glow after some hard driving
Old Sep 8, 2008 | 12:46 PM
berlinetta
starts up fine. i let it idle for a while looking for a vaccum leak causing a high (2000rpm) idle. couldn't find any leaks, then i noticed the header glowing.
don't know my AFR's, not sure on the EGT, and the pressure sensor is hooked up.
Old Sep 8, 2008 | 03:09 PM
@ pipnorcali
pull the plugs and take a look at least.
Old Sep 8, 2008 | 03:48 PM
berlinetta
i have spark from all plugs, timing was the issue, now i have a high idle and i've adjusted the idle all the way down. still at 1500rpms
Old Sep 8, 2008 | 04:16 PM
CyberPitz's Avatar
Boost ahoy!
I was hoping for pics, really.
Old Sep 8, 2008 | 05:34 PM
Sideways7's Avatar
An idle that high is not from a vac leak. If its a vac leak it will idle badly and you will have to artificially raise the idle to keep it from dying. Check for stuck throttle plates, stuck high-idle cam, or malfunctioning BAC.
As for the glowing headers, its either running really lean, or really rich causing fuel to ignite in the header. How does it run, and does it smell badly of unburnt fuel?
Also, how sure are you the timing is right?
Old Sep 8, 2008 | 05:35 PM
check the timing with a timing light.
Old Sep 8, 2008 | 05:51 PM
misterstyx69's Avatar
Retired Moderator, RIP
My header glows too,after spirited driving..Car runs fine...Wouldn't you?..after getting 1200 degree exhaust thrown at ya?
Old Sep 9, 2008 | 01:38 AM
berlinetta
BAC is removed, the idle is smooth, but when i adjusted the throttle plate stoper it idles really shitty, and i don't know where the high idle cam is.
as i said before about the glowing. i know it was the timing because i adjusted it and the glowing stoped.
Andrew7dg
Aug 6, 2017 01:41 PM
