IF YOU DON'T HAVE THIS YOUR MOTOR (KA-BOOM!!!!!)
Old May 9, 2002 | 07:57 PM
JeffShoots's Avatar
FilterMag work or waste of $$$
Now that I have your complete ATTENTION!!!!
Always looking for more longevity in the rotary. Any testimonials or better try one and cut the filter open after to see some debris?
http://www.filtermag.com/
Hey Jason, if this thing works I want a Group Buy.
Later, Jeff
Old May 9, 2002 | 08:36 PM
jpandes's Avatar
I'm read their site. Now, I'm curious too.
Old May 10, 2002 | 01:06 AM
JeffShoots's Avatar
OK, OK? No one has tried it? Or they just won't admit to it?
Old May 10, 2002 | 01:21 AM
happyham's Avatar
looks as useful as those fuel injector cleaners that you pour into your gastank. if you got chunks of metal circulating through your oil circuit, then it won't matter if the metal gets magnetized to the filter (since those chunks of metal are probably from something fuxored inside your engine)
Old May 10, 2002 | 01:38 AM
A-Spec's Avatar
those things has been around for awhile. www.beartrap.com is another one...
I doubt it'll help any, changin oil every 3k is still the best way.
David
Old May 10, 2002 | 02:24 AM
93TTRX7's Avatar
oil isn't even the main cause of rebuild
Old May 10, 2002 | 12:32 PM
Bacon's Avatar
IRS 4 Life
pure one's alredy have a magnet in it....
Old May 10, 2002 | 02:10 PM
luneytune's Avatar
Rotaries don't have valve trains or steel surfaces on the rotor housing so there isn't a lot of metallic debris formed, even the oil pump is rotary! In pissing engines everything wears everywhere so much more metal is produced especially in the domestics with their loose tolerences. We change oil because of heat destruction not metal contaminants. IMHO.
Old May 10, 2002 | 02:26 PM
GoRacer's Avatar
Speed Mach Go Go Go
I agree with Loony Tunes
http://www.synlube.com/ offers the same thing and you're supposed to use the filter w/magnet before you use their lifetime oil. It says (the oil) is not suitible for rotary's though.
Old May 10, 2002 | 02:50 PM
Goblin's Avatar
What am I missing here?
If anyone is really that worried about metal particles just go to AutoZone and buy a magnetic oil pan bolt for, like, two bucks.
I get a little bit of sludge on the bolt everytime I change my oil. No big deal, but I know it's not circulating into the engine, at least.
cristoDathird
28
May 30, 2019 08:47 PM
incubuseva
14
Sep 3, 2015 12:37 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
