My steering is really tuff
Old May 9, 2002 | 07:45 PM
RX7Kid's Avatar
i just bought an TII the steering is really hard to turn rolling and stoped i know it doesnt have power steering, it is just alot stiffer then i think it should be compared to otheer non powersteering cars.
Old May 9, 2002 | 07:57 PM
BDoty311's Avatar
88 AE
YOu will get used to it. When I first drove my RX i thought that it was a real pain in the ***. But now i dont even worry about it, in fact i perfer it over power streering know because its just too easy.
VetteKiller's Avatar
might need some grease, mine was like that when I first got it
Old May 10, 2002 | 04:26 AM
RETed's Avatar
You need to work out more.
If you're running 225 or thinner tires up front, there is no excuse for not being able to turn the wheel.&nbsp Are you female?
-Ted
Old May 10, 2002 | 08:18 AM
jacob's Avatar
Originally posted by RETed
Are you female?
-Ted
well he is from Beaverton, OR!!
Old May 10, 2002 | 08:38 AM
Josepi's Avatar
Despise Enmity
Did you put a manual steering rack on, or just remove the PS?
Old May 10, 2002 | 09:10 AM
bob13bt's Avatar
Fixed the wheelhop
Beaverton, OR!!! Thats ******* classic!!
Could be ball joints, or possible poor alignment angles.
Grease the ****, if possible. Jack the front of the car up, grab each tire from left to right, and try to move the wheel. It will move freely because it has no weight of the car on it, but try to feel for any excessive (sloppy) free play in the steering. If you feel clunks, it is probably tie-rod ends.
If you can move the tire by grabbing at the top and bottom, then your wheel bearings need to be tightened or are worn out.
Old May 10, 2002 | 10:43 AM
RETed's Avatar
Manual steering system rarely go bad.&nbsp Unless the car has been in a front end accident, I doubt it could sieze by itself - there's an easy test to perform.
Jack the car up and turn the steering wheel all the way left - all the way right.&nbsp It should turn VERY easily and very smoothly.&nbsp This will eliminate any problems with the steering system itself.
-Ted
Old May 12, 2002 | 10:59 PM
RX7Kid's Avatar
Thanx and no i am not a female it is really stiff..
Old May 13, 2002 | 03:02 AM
SonicRaT's Avatar
Super Raterhater
Hey, I've been to Beaverton a couple of times. Ever been on the south end of Oregon near Medford? I used to live there, definatly prefered being south of Portland!
Old May 14, 2002 | 05:26 PM
RX7Kid's Avatar
Yeah i have been to the south end of portland
Old May 14, 2002 | 05:33 PM
MaxRX7's Avatar
hambre y sueño
-Ted
OMFG, that was hilarious !!
Old May 14, 2002 | 05:50 PM
RX7Kid's Avatar
TED It is fucked up i have driven cars without PS i was asking for help not ****.
Old May 14, 2002 | 07:09 PM
RETed's Avatar
If it's fucked when why the **** you asking us for help?&nbsp You can't figure out that you need the replace the whole godamn thing if you know it's fucked?
-Ted
RyanFox
Sep 18, 2015 09:09 PM
