launching techniques
Old May 9, 2002 | 07:15 PM
john's Avatar
hey i was just wondering what type of techniques you guys are using to launch your car.
Old May 9, 2002 | 07:16 PM
r0gu3's Avatar
Boostless FD
I just rev up to around 3500 rpm and dump the clutch. I find I get the best results doing that.
-r0gu3
Old May 9, 2002 | 10:33 PM
what would the best way to launch to get the max life out of a clutch?
heat being the foe for a clutch, will releasing slowly cause for harm?
what is the best rpm?
Old May 9, 2002 | 10:43 PM
rx-7fc's Avatar
r0gu3 what do you run in the 1/4
Old May 9, 2002 | 11:16 PM
Jahoo88's Avatar
i think slipping the clutch kills it on launches. If you dump it, the tires spin but the clutch grips right away and doesnt wear as much.
I have 6 ports wired open and launch at 4k with 215/60 14H rated tires. This ends up in the tires spinning till i get over 4k and then the car goes.
Anything under that and it bogs.
Usually my front license plate that i keep on the dash just behind the windsheild will fly out on launch.
Im guessing i run mid - low 15's.
alfred1976
RX-7 Audio/Visual Lounge
Dec 3, 2015 03:06 AM
matty
47
Oct 4, 2015 02:45 PM
Heedlessone
Sep 16, 2015 11:31 AM
IB Cristina
West RX-7 Forum
Aug 20, 2015 05:46 PM
