14PSI & stock motor = ?
Old May 9, 2002 | 04:33 PM
es's Avatar
es
Is 14PSI too much for a stock FD motor considering the fuel system & intercooler have been upgradded?
Walbro pump, 1300cc secondaries, Power FC, IC, DP, CB, non-platinum 9's all around... Oh, & I torqued the sandwich bolts when I did the clutch.
TIA,
Eric.
'93 Tour 300RWHP@12PSI
???RWHP@14PSI
Old May 9, 2002 | 04:37 PM
daze's Avatar
14psi is safe since you have an upgraded intercooler.
Old May 9, 2002 | 04:40 PM
user 84205's Avatar
what does the intercooler have anything to do
with it.....?
Old May 9, 2002 | 04:46 PM
daze's Avatar
Im not sure but from what i've read before the stock intercooler only safe for 13psi...!!
Old May 9, 2002 | 04:49 PM
Zoomspeed's Avatar
with it.....?
I belive what it is is that the more you pressureize the air the hotter it gets, and the stock IC cooling capabilities arn't enough to run 14 PSI w/o risking detonation.......I think.
Old May 9, 2002 | 04:50 PM
DeNguyen's Avatar
i think the correct word you are looking for is " efficient"
Old May 9, 2002 | 05:47 PM
Lost Time's Avatar
Chimera Driver
The stock ic is fine for short bursts. It does not, however, cool efficiently enough for extended high boost runs.
Old May 9, 2002 | 07:23 PM
94touring's Avatar
The stock motor can handle 14psi no problem. These engines are stronger than people give them credit for, its the tuning that is vital. I run 18psi everyday, I would even feel comforatable running 20psi, but after that you would want race fuel to keep from detonating.
Old May 9, 2002 | 07:32 PM
Johnny's Avatar
OG
Denny's got it right...14+ more boost and that's a lot of heat for the stock turbos to be efficient.
sure some people dyno running 16-18 pounds...but they are definately shorting their life span
Old May 9, 2002 | 07:44 PM
94touring's Avatar
Oh yeah, and I don't suggest running more than 14 psi on stock turbos, like the others have stated.
Old May 9, 2002 | 08:02 PM
es's Avatar
es
14PSI on stock motor
Thanks for all the input guys.
I was told by some that anything over 12PSI would damage the oil control seals, but there's no upgrade for those anyhow...
I think where most people run into problems is running the stock or near stock fuel system at 14PSI. With the Pettit or M2 ECU that boost level would push the injectors open at a 99% injector duty cycle.
I completely agree with the high charge temps causing pre-ignition... That's why I upgradded the IC.
So, I guess I better start doing some tunning in the higher boost cells.
Old May 11, 2002 | 02:18 PM
H2o's Avatar
H2o
do you even know what hell you're talking about?? do your homework before you spit out stupid answers.
Old May 11, 2002 | 04:25 PM
R Xplicit's Avatar
basically, running too high of a boost curve will over load the stock turbos, and then they become weak and VERY inefficient. they will become heatsoaked and be more debitrimental than helpful. however, 14psi is ok on st. twins. it is when you push the envelope of 16 and upwards that you will experience these problems...
Old May 11, 2002 | 04:58 PM
93TTRX7's Avatar
what's so stupid about it? he's right...you're gonna need a good IC for cooling. I don't give a crap how high octane you're running without a good IC YOU WILL DETONATE.
cristoDathird
28
May 30, 2019 08:47 PM
Pawes
Aug 20, 2015 07:36 PM
sYnth.
Aug 19, 2015 06:27 PM
