clutch pedal??
Old May 8, 2002 | 11:19 PM
marshp's Avatar
Registered Rx7 Owner
clutch pedal??
just today my car has been acting kinda weird
its an 85 gs rx7 manual transmission
today when i was coming to stop i put it in neutral to stop so i could take my foot off the clutch and wait for the light to change, then i notcied my clutch pedal was stuck to the floor and i had to hook my foot under it and pull it up to change gears....then i managed to change gears and again the clutch pedal stuck to the floor and it wouldnt come up
what could be the possible problem? maybe the master cylinder?
Old May 9, 2002 | 12:09 AM
Redwood's Avatar
Find Racing
Weird, but it just sounds like there isn't pressure holding in the system somewhere. Check the fluid level in the master cylinder of course. Possibly a leak in the system somewhere. Check the rubber hose connections.
It's odd that you could still use the clutch if there wasn't pressure, so I may be wrong. Hopefully it's something easy.
Good luck.
Old May 9, 2002 | 12:42 AM
4ohfour's Avatar
My clutch peddle sticks like that sometimes too, not sure what it is....
can anyone shed any more light on the problem?
cheers'
Old May 9, 2002 | 01:20 AM
Project84's Avatar
Open up! Search Warrant!
Check where the clutch pedal attaches to the car and see if there is a spring attaching the pedal to a bracket. Next, you may have to check the clutch master cylinder and the release cylinder. Haynes manual shows how. It doesn't look too difficult, and you may just need to replace a seal inside one of the cylinders.
Old May 9, 2002 | 01:22 AM
MarkPerez's Avatar
Tennis, anyone
Are you saying that sometimes,,the clutch pedal gets
stuck,,'to the floor' then you pull it back up , then what,
it works for awhile,untill the next time..and there's presure in the clutch hydro. system ??
what colour is the fluid in the master (clutch) cyl.
clear,? dirty ,?
Old May 9, 2002 | 01:27 AM
duboisr's Avatar
mine did this .garfinkle rebuilt the master and slave units no more troubles parts were less than 50 dollars as I remember
Old May 9, 2002 | 02:56 AM
theNeanderthol's Avatar
the torquinator
Same thing happened to me. Mine was the slave cylinder. I think yours if most likely eithee the slave or master cylinder, or the flexible hose that leads to the slave cylinder. Bleed the system really well using good brake fluid too.
Old May 9, 2002 | 04:50 PM
marshp's Avatar
ok thanks for all your guys help your the best
ill go try and check all the stuff you said to and ill bleed the clutch
ill let you guys know how it goes
thanks again
Old May 9, 2002 | 08:11 PM
marshp's Avatar
ok i went out and bled the slave cylinder and the master cylinder, and there seems to be as if there is a bit of air in the line, so im going to buy an new master cylinder and hopefulyl that will fix the pressure leak if thats even the problem
Old May 9, 2002 | 08:42 PM
MarkPerez's Avatar
Tennis, anyone
what colour was the fluid when all that happened ??
clear,,?? dirty,, ??
Old May 9, 2002 | 10:23 PM
WackyRotary's Avatar
standard combustion
WEll my thought is either something under the dash it keeping it down or there is a nic inside the master cylinder causing it to stay down or the return spring is broke inside of it or binding or something. If its a master cylinder get a new one or find a junkyard one. DO NOT Buy a rebuild kit!!! They suck and will leak a few weeks later...
Old May 10, 2002 | 01:18 AM
marshp's Avatar
the fluid was quite dirty i would say. and pretty old, but we bled the lines and put in new fluid and it didnt fix the problem, yes tommorow i shall buy a new clutch master cylinder and hopefully that shall fix the problem, otherwise i dont know cause i dont think it has anything to do with a spring.
Old May 10, 2002 | 01:40 AM
MarkPerez's Avatar
Tennis, anyone
good call,,i rebuilt my clutch master a couple of weeks
ago,,i would say buy a new master,,if you can,,,
one sign of a system failure from the master is when
the fluid turns dark and dirty..before installing the new master make sure to bench test (prime) it first
Old May 11, 2002 | 05:09 PM
marshp's Avatar
nice! the problem has been fixed!
it was just the master cylinder and i bled it and primed it and everything is workign! excellent...
Old May 11, 2002 | 05:48 PM
yayarx7's Avatar
Are you Nucking Futs?
I had a master cylinder go bad. It did as you descibe. The fluid was filty!
Old May 11, 2002 | 07:41 PM
Project84's Avatar
Smile
Another happy RX-7 customer
Old May 14, 2002 | 06:24 PM
FuLLsMoKe's Avatar
"By the beard of Zeus!"
Mmm.... I'm having problems with my clutch lately--Today, while I was coming home, I lost almost all pressure in my clutch, pumping my way home. The clutch pedal not only stuck to the floor, but I felt absolutely zero resistance in the clutch travel. So... I tried to find the problem--if it was a broken master or slave cylinder, but I can't find the elusive blue book (Haynes manual). I have an 85 GS... I know where the master cylinder is, but I'm not so sure where the slave cylinder is--is it where the bleed screw is?
Anyway... Any help is appreciated =)
Thanx
Old May 14, 2002 | 07:39 PM
Johnny D's Avatar
The bleed screw next to your transmision is part of the slave cylinder. It is only about three inches long, sits right on top of the transmission, follow the pressure hose back from the master cylinder. I had the same problem a couple months ago, it was the slave cylinder for me and it takes about twenty mintes to replace.
Old May 14, 2002 | 07:44 PM
damn hippies
i had my slave cilender changed....it only happends now when my dad drives it...i think you have to be touchy with the clutch thats all
Old May 14, 2002 | 08:00 PM
FuLLsMoKe's Avatar
Haha, when my dad got in the car to try the clutch, about half the pressure came back--MAGICALLY--compared to zero pressure I was facing... And I drive the car EVERY day and love it--it should like me more! =(
Is there a sure way to identify that the slave cylinder is dead? (or the master?). I think I know how to tell, but i just wanna make sure =)
Thanx
Old May 14, 2002 | 08:52 PM
MarkPerez's Avatar
Tennis, anyone
What colour is the fluid ??? clear ? dirty ?,,,
Old May 15, 2002 | 04:05 PM
FuLLsMoKe's Avatar
Mine is dirty... I've been meaning to change all the fluids in my 7 lately, but no time for my poor 7 =(
Old May 15, 2002 | 08:23 PM
ghetto-rx7's Avatar
i want the haynes manual
were can u get it i dont think theres a pep boys around here and i heard thaz were u get it??
Old May 16, 2002 | 01:04 PM
MarkPerez's Avatar
Tennis, anyone
I know this for fact ,,,when the fluid turns dark or dirty
that is the master starting to fail..the colour(dark)(dirty)
is caused when the master gets contaminated by metal
partacules from the walls of the master ...the slave
doesn't make direct contact with the fluid, like the master does...so look into the master.
