What is considered a early model 93?
Old May 8, 2002 | 06:47 PM
mazdaspeed00's Avatar
For Sale
i am about to go look at a 93 and was wondering from what build date to what date is considered an early model rx-7. i believe anything pre 93 is considered to be an early model. am i correct?
thanks guys
Old May 8, 2002 | 07:04 PM
j9fd3s's Avatar
Community Builder
all of the 93's were built in 1992...
at this point your looking for a car with all of the updates done to it. (note: all of the significant updates happened after 96) you want one with all the bugs fixed. an all original low mile car would scare me because they werent the ones that had the intake gaskets replaced, and the vaccum hoses redone, and all the oil leaks fixed etc.
mike
Lost Time's Avatar
Chimera Driver
Not sure exactly what you're asking, but you could buy a 93 as early as Fall of 92 I believe. That is as early as you'll see in the US.
Old May 8, 2002 | 07:33 PM
For Sale
since all 93's were built in 92 then here is what i am tryin to ask to clear up things.
i know that early model 93's had problems with their dash peeling. i also know that the type of plastic they used was changed in the middle of production during 92.
what i am tryin to get at is from what months to what months in 92 am i tryin to aviod.
i hope this makes my question seem a bit more clear
Old May 8, 2002 | 07:36 PM
mightyslash's Avatar
Will Work for Ferrari
I believe the earliest production date was Dec. 1991.
Old May 8, 2002 | 07:49 PM
luneytune's Avatar
Lol
It was Dec 1st 1991 the first FD3S.
3rd Gens aren't out there by the millions, so I doubt whether you will be able to be that picky. As a car goes through production small changes are made sometimes daily so there isn't a magic date to have. The best 93 to have is a late production 95. Good luck anyways.
Old May 8, 2002 | 08:01 PM
Johnny's Avatar
OG
go to the newbie sticky link...search those pages for TSB (technical service bullutins) somewhere they should be listed by VIN numbers...that way you can compare and see if your car is effected...
personally I would just try to find one in great working condition....it will be pretty hard to know if some of the stuf was fixed by the original owner..or the second or the third...
Old May 8, 2002 | 08:42 PM
JConn2299's Avatar
reliable performance
This will give you some of the information you're looking for:
http://www.speednation.com/mystery2.htm
Old May 9, 2002 | 12:48 AM
For Sale
thanks guys
Old May 9, 2002 | 03:19 AM
JspecFD's Avatar
If you look at the running changes done at the factory, any car with a build date BEFORE 6/92 is considered an early '93. Mazda did several changes during 5/92 so a car with a 6/92 build date is safe. Still, the later '93 the better such as the strengthened 5th gear fix(from TSB, affects cars built ~8/92 and before VIN ~10300).
Earliest FD build dates were 12/91 although only around a couple hundred were built. If you compare build dates to VIN's, you'll notice that Mazda built a TON of FD's in the first several months of '92 before slowing production.
Old May 9, 2002 | 03:35 AM
user 84205's Avatar
Re: Lol
That may have been the first time out, but they started in 92 offically.
Off the subject sort of, the 92 had 16in rotors didnt it?
Old May 9, 2002 | 04:16 AM
JspecFD's Avatar
TSB for dash peeling:
4. BLACK FINISH PEELING FROM INTERIOR TRIM.
Service bulletin #056/92, Category S, Issued 12/15/92
Applies to vehicles with a VIN of JM1FD331**P0207441 or lower
produced through August 4, 1992. Some vehicles may experience the
black finish peeling from the following interior trim parts:
FD01 55 210B 00 Center Panel (Holds the radio and climate
controls)
FD01 55 420E 00 Meter Hood (Holds all the gauges)
FD01 64 471D 00 Switch Panel (For 5-speed manuals, I think)
FD01 68 4LY 00 Switch Panel (For automatics, I think)
FD01 68 4M0A 00 Arm rest trim lid (L)
FD01 69 44XA 00 Front Assist Grip (R)
Old May 9, 2002 | 04:25 AM
For Sale
thanks guys that clears a lota things i had on my mind up. u guys are very helpful as usuall
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
FD3S_wanted
Sep 22, 2015 06:18 PM
