installed midpipe, now i have a problem?
Old May 8, 2002 | 05:58 PM
Question installed midpipe, now i have a problem?
i installed my midpipe today. and now my check engine light is on (oxygen sensor code). also my crapometer a/f gauge is stuck on the fisrt lean mark. when i installed the mp, i left the hose that connected into the converter from the airpump dangeling. could this be the problem? i also noticed that wire going to the o2 sensor was a little loose, probally my problem right? i had to drive it home from the shop i was working at, 10 min drive. do you think i messed anything up? im going to wait for it to cool down, then ill check the o2 sensor wire. anybody got any other suggestions? thxs, brad
Old May 8, 2002 | 06:03 PM
mjw's Avatar
mjw
Sounds like you are on the right track, the O2 sensor wire being loose could cause both of your problems since they seem related. I don't see how a midpipe would cause your problems.
Matt
Old May 8, 2002 | 06:25 PM
ok it was the O2 wire. i guess i moved it just enough today to break it off. its a clean cut even with where it plugs into the sensor. please tell me theres away to reconnect the wire, without buying a new sensor. anybody with past O2 experience got any suggestions. thxs, brad
Old May 8, 2002 | 06:28 PM
BlackR1's Avatar
Meesto Spakaro
you will have to resolder it... i would just suggest buying a new Bosch Universal if you havent changed your O2 sensor in a while
Old May 8, 2002 | 06:30 PM
thanks R1. how much are they and where can i got one from?
Old May 8, 2002 | 06:40 PM
BlackR1's Avatar
Meesto Spakaro
any auto parts store for 20-30 bucks... really easy install. Dont worry you didnt run lean... since your o2 sensor got disconnected your AF didnt get a reading...you most likely ran ridiculously rich...maybe even flooded the car. You'll probably have a hard time starting her again, but just do a search on how to unflood your FD if she doesnt start up quickly.
Old May 8, 2002 | 06:45 PM
price
thanks for your help. i just pulled up one of your old posts and got the info. im on the way to the store.
-brad
Monsterbox
Jul 29, 2022 10:48 PM
Skeese
Rotary Car Performance
Oct 28, 2020 11:01 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
