Hks T51 R
Old Aug 17, 2008 | 02:56 AM
MonsterRex's Avatar
KnightSports FD3S
Hks T51 R
Hi guys, This is my first post here. I know people on here are experts, so that's why i wanted to ask if was possible to fit an HKS T51r single turbo to a standard fd3s engine without any porting.
The reason for this is that my engine has just been rebuilt about 4000 miles ago and i really can't spend 3k for another rebuild to get the porting done.
Nearly everyone i've been speaking to in the uk said that if i fitted this turbo on a standard engine it would not spool. What do u guys think?
Any clarifications on this would be very much appreciated. Thanks a lot...
Old Aug 17, 2008 | 06:58 AM
David Hayes's Avatar
That's a big turbo for a non-ported engine. I can't answer if it will spool, but I don't think the turbo would ever hit its efficiency range thus making it pretty pointless. Go with something like a GT35R, it would be a much better fit.
Old Aug 17, 2008 | 08:07 AM
ErnieT's Avatar
Living life 9 seconds at a time
It will spool fine. Porting your engine will give you more of a power band, but you'll be fine. Do it!
Old Aug 17, 2008 | 09:25 AM
MonsterRex's Avatar
KnightSports FD3S
Thanks for all the replies guys. I'll stick it on and let u know how it goes.
Old Aug 17, 2008 | 10:02 AM
Turblown's Avatar
Turn up the boost
Just run a big enough exhaust system and you will be just fine.
Old Aug 18, 2008 | 08:53 AM
blitzboy's Avatar
it will spool but quite late in the rev range, you might get 14 psi by 5.5k, you will lose low down grunt, what you using the car for, drag,track, or street?
Old Aug 18, 2008 | 10:26 AM
Viking War Hammer's Avatar
*** Bless The USA
you'll be fine....... i got 28 psi by 4500 on a streetport........ stock ports shouldn't be too far off
Old Aug 18, 2008 | 01:12 PM
MonsterRex's Avatar
KnightSports FD3S
Hi Blitzboy (Mark), i saw u briefly at Rotorstock on Saturday and u were talking to Ash. Didn't get a chance to speak to u as it was raining quite heavily. username on mrc is chr007.
I'll be using the car for street (weekends) and drag.
Old Aug 18, 2008 | 01:17 PM
MonsterRex's Avatar
KnightSports FD3S
I realise that porting is needed to get full power from this turbo but not right now as my engine has just been rebuilt about 5000 miles ago and don't have the cash to do a rebuid again.
Old Aug 18, 2008 | 01:22 PM
junito1's Avatar
F**K THE SYSTEM!!
J-rat would be the person to ask?
I dont know what turbos j-rat used, but i know he kept his stock ports with some nice size turbos.
Old Aug 18, 2008 | 03:53 PM
JEROME's Avatar
Hello,
Here is my 2 cents.
http://www.youtube.com/watch?v=I594HQCHgHc
Old Aug 18, 2008 | 09:09 PM
hurleysurf24's Avatar
wtf rotary wtf
youre looking at the one on ebay huh
Old Aug 18, 2008 | 09:46 PM
calicrewchief's Avatar
RotorHead
Whats the difference between the SPL and KAI? I don't understand what makes the T51R better than say a Garrett ball bearing.
Old Aug 23, 2008 | 05:30 PM
Works Concepts's Avatar
Registered User
The SPL is a larger turbo than the KAI, and they are both Garrett turbos but not ball bearing. They have ball bearing versions of each through. The compressor housings are unique to HKS. Its a matter of preference as too which is better.
Old Aug 23, 2008 | 06:34 PM
*** Bless The USA
SPL isn't worth it. Search bro, I already went through this.
Old Aug 23, 2008 | 06:42 PM
genocide #7's Avatar
I'd say go with something more streetable like a t04r or t04z, it has a better response then a t51r spl or kai. If your looking to make lot's of power than porting is the way to go. I'm running a street port, and planing to run the gt4088 turbo. My advice is to do more research on the turbo, and look at the turbo maps it helps alot.
Old Aug 23, 2008 | 06:48 PM
*** Bless The USA
actually, if you want a KAI, get it.............. mine tore the street up pretty good
Old Aug 23, 2008 | 07:03 PM
Busted7's Avatar
Will work for horsepower
Your getting old Eric living in the past!
Old Oct 13, 2008 | 04:34 PM
STUART.KN SOLUTIONS's Avatar
have your new plugs now we can map it to 1 bar maybe 1.2 give me a call
Old Oct 13, 2008 | 04:44 PM
rx72c's Avatar
Top Answer: 1
Ive got a gt42 bush bearing on a non ported cosmo engine.
have made 422rwhp on dyno dynamics at 18psi(here in aus so are power figures are lower), and i havnt had a chance to add timing or lean it out much.
It comes on hard at 5500rpm and power starts to die off at 8400rpm. But then again like i said. I can make it go for longer. just have not put any timing in the top end yet.
Old Oct 13, 2008 | 04:52 PM
he was getting break up so we order plugs & leads (only running 7 psi at mowon ngk 7/9s should get him to about 16/18 with gready 10 11s
Old Jan 19, 2009 | 04:36 PM
mono4lamar's Avatar
In the burnout box...
Strange question, how many lbs per minute is the regular t51r rated? I never knew this and still cant find it...
Old Jan 19, 2009 | 08:20 PM
fighteryu's Avatar
Could you link us? I'm having problems finding it. I wouldn't mind reading up a bit more into the T51. I hear nothing but good things about this turbo. The SPL is not cheap...
Old Jan 19, 2009 | 09:14 PM
silverTRD's Avatar
Time or Money, Pick one
Dayuum!!!!! 28psi by 4500! that's sweet! me likey
Old Jan 20, 2009 | 11:59 AM
MonsterRex's Avatar
KnightSports FD3S
Right guys, sorry for not updating about the turbo.
What can i say? The T51R is awesome, the noise it makes is unbelievable. People can hear u coming way back, sounds like a jet. It provides very good performance too, okay there's a little bit of lag because i've only got a medium street port but when it comes on u really have to hold on.
