Front anit-sway bar disconnected
Old May 8, 2002 | 04:36 AM
alien_rx7's Avatar
Interstate Chop Shop CEO
Unhappy Front anit-sway bar disconnected
Unfortunately the other day while under the 7 looking around the front suspension I found something disturbing.
The front anti-sway bar was disconnected from the suspension arms and it looks like the mounting points are
worn from the slapping of the bar on them while driving so it doesn't look good for hooking it back up without
finding new mounting points to put into the suspension arms.
While I'm looking for those plus all the bushings and stuff, how does a 7 react with one connected? Will I notice
a big difference with it connected back up when going through the tight corners? Right now it oversteers like crazy through the corners with just a touch of acceleration, but I thought that was like any other stock rear wheel drive vehicle...
Old May 8, 2002 | 04:48 AM
REVHED's Avatar
Hunting Skylines
Bah, just leave it off... much easier to get it sideways. j/k
Old May 8, 2002 | 06:48 AM
Directfreak's Avatar
I am a Jeeper Now.
If it was the back one, I would say leave it off (many people remove perfectly good working ones.)
The front one is important to have. Go to a welding shop and see if they can reinforce or "tack on" some new reinforcement points to the original locations.
Changing the mounting locations could have adverse effects to your handling.
Old May 8, 2002 | 09:47 AM
jeremy's Avatar
male stripper
putting it back on will help turn in and flatten the car out. you should still be able to oversteer but the car will be more stable in turns.
matty
Jan 18, 2020 10:39 AM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
