MoTeC Area is for discussing the MoTeC EMS.
MoTeC m4pro
Old Aug 12, 2008 | 11:11 PM
camlz's Avatar
RX-07-FD
m4pro
Can anyone recommend the motec m4 pro cause i can pick one up off a mate cheap cause he's getting the 800.
is it any good for the fds? and how much work will it be to install???
camlz
Old Aug 26, 2008 | 12:26 AM
camlz's Avatar
RX-07-FD
Hello???
Anybody Out There????
H E L L O ? ? ? ? ?
Old Aug 26, 2008 | 10:44 AM
Chaotic_FC's Avatar
the m4 is an amazing ECU
it only has 4 injector outputs though
look it up on motec.com
Old Aug 26, 2008 | 10:51 AM
2a+RoN's Avatar
It would be a great ecu if you can grab it. Very capable, but has limited outputs, so if you plan on using the ecu to run a bunch of aux stuff, you would need an ignition expander to free up some outputs. Install is pretty straight forward if you are familiar with wiring, no more difficult than wiring in any other standalone.
Old Aug 27, 2008 | 01:20 AM
camlz's Avatar
RX-07-FD
thanks guys
4SFED
Old School and Other Rotary
Apr 7, 2002 11:54 PM
