Misfiring HELP
Old May 8, 2002 | 02:27 AM
Unhappy Misfiring HELP
Here's the problem: I give the car some throttle either in 2, 3, 4, or 5 and above 5 psi, and above about 4500 rpm, the car's power is not smooth and it seems to be either hesitating or misfiring. Also the exhaust tone changes from smooth to a sputtering sort of crackling noise.
PLEASE HELP
Mods done to car:
2.5" exhaust with high flow main cat
hks powerflow intake
hks f-con
ball and spring boost controller
t3 / t4 turbo upgrade
thank you, Dave
Old May 8, 2002 | 07:50 AM
Josepi's Avatar
Despise Enmity
Does it do it at ALL during deceleration? Checked the TPS? New injectors/cleaned injectors? Signal from the ECU to the secondaries good?
Old May 8, 2002 | 11:12 PM
I don't think it the injectors as they were just bench tested. As far as the elctical signal to the 2ndaries...mabey it's messed up....how can I check it? What else could be cousing these high boost/rpm stumbles?
HELP!
Old May 8, 2002 | 11:44 PM
KenshinFC's Avatar
did you upgrade your fuel pump? and what size injectors are you running? maybe you're leaning out your car...
- Kevin
Old May 8, 2002 | 11:59 PM
NZConvertible's Avatar
I'm a boost creep...
I had exactly the same symptoms. Turned out the be a stuffed leading plug lead. Replaced it and it ran like new.
Old May 9, 2002 | 11:39 AM
RETed's Avatar
Kinda off-topic, but how did you get that T3/T4 hybrid onto your FC?
-Ted
Old May 9, 2002 | 03:01 PM
86Rx7GXL's Avatar
hey NZConvertible what is and were is the leading plug lead? what did you do to fix it
Old May 9, 2002 | 04:45 PM
The spark plug lead between the leading coil (behind LHS headlight) and the leading (lower) spark plugs. I just replaced the broken one but I figure if one failed the rest can't be far behind, so I'm getting a set of Magnecore KV85's soon.
Old May 12, 2002 | 04:08 PM
-Ted
It's a Knight Sports Turbo upgrade kit. It came with a new intake housing and new, upgraded impellars that work with the stock exhaust housing. It's actually a Turbonetics Intake.....
alphawolff
Nov 17, 2015 05:57 PM
R7rexy
19
Sep 2, 2015 10:24 AM
rxmiles
Aug 24, 2015 02:07 PM
Wolf_
Aug 11, 2015 04:23 PM
