Help With COne Filter Kit!!!!
Old May 8, 2002 | 12:23 AM
myron96's Avatar
Can someone please tell me where the hell this aluminum adapter goes when i install the cone air filter kit. I have tried and tried to figure this out, the filter is on my car clamped to the front of the MAF. Where the hell does this go?
Old May 8, 2002 | 01:46 AM
RETed's Avatar
You could start by telling us what kinda car you've got...
-Ted
Old May 8, 2002 | 07:36 AM
Josepi's Avatar
Despise Enmity
Ted, you should be more resourceful!
Anyhow, since you have a 89, you don't need the adaptor plate (it's for 86-88's). You should just be able to clamp the filter itself to the end of the AFM.
Old May 8, 2002 | 08:57 AM
Roundabout's Avatar
Village Idiot
I have an 87 Base with the K&N cone filter. What do I do with the open port that goes to the air pump if I don't have an air pump?
Old May 8, 2002 | 10:15 AM
blu_gxl's Avatar
well, you need a block off plate
james
Old May 8, 2002 | 06:17 PM
Roundabout's Avatar
Village Idiot
I was talking about the port on the back of the filter.
Old May 8, 2002 | 07:27 PM
ReZ311's Avatar
KM48 Burnout
plug it then
Old May 8, 2002 | 08:44 PM
are there after market mass air flow sensors i just have my cone tightned right onto mine and it works fine i was just woundering if theres any better MAS's?
Old May 9, 2002 | 01:00 AM
myron96's Avatar
Hey thanks, Yea, I just have mine clamped onto the MAF. Didint need the adapter.....
Old May 11, 2002 | 01:33 AM
Originally posted by ReZ311
plug it then
I think he's talking about the hose that goes from the air box to the air pump. I don't think you would want to plug that. Go to Pep Boys and get a rice boy breather filter, and stick that on the end of the hose.
Old May 27, 2002 | 04:10 PM
myron96's Avatar
Yep, actually went to autozone, and got one for 7 bucks
Old May 27, 2002 | 04:19 PM
NZConvertible's Avatar
I'm a boost creep...
Not for the FC.
Old May 28, 2002 | 12:18 AM
FC3S Drift's Avatar
7 UP URS!
oh your supposed to leave the hose on? will there be a problem if i just put that little thing on the air pump itself?
Old May 28, 2002 | 11:17 AM
I think that's where the air pump draws in air. I would imagine it could cause problems if the air pump is trying to draw in air, but the hole is plugged up.
Old May 28, 2002 | 11:37 AM
FC3S Drift's Avatar
7 UP URS!
well ive been driving like that for about a month now and i havent ran into any problems.....................yet...
Old May 28, 2002 | 01:56 PM
hybridracer's Avatar
I Post In The Nude
You havent had any problems? When my wasnt getting enough air the car would run like **** and wouldnt go past 6k.
Old May 28, 2002 | 02:19 PM
FC3S Drift's Avatar
7 UP URS!
there wouldnt really be an advantage if i were to put the hose back on with the breather on the end would there? just curious
Old May 28, 2002 | 02:55 PM
lechnoid's Avatar
Wheeeeeeeeee!
I used a chevy 1 1/4" breather filter and made a mount that clamps in with the MAS and uses the stock hose to filter the air pump inlet. In retrospect, I wish I would've just used pantyhose over the inlet...
If you're using custom valving off the air pump for the 6 ports like I am, you need to prevent rocks from getting into the air pump. Nothing more.
If you filter or don't filter the air pump, it should make no performance difference. I actually gained low rpm psi when I put the filter on my air pump and now can't back off the pressure enough to keep my ports closed below 3K. (SUCKS!) So I'll be going to an rpm actuated switch on a GM air ride suspension pump.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
