Haltech E6X O2 sensor !!!
Old Aug 8, 2008 | 11:26 PM
Thedays's Avatar
E6X O2 sensor !!!
Hi guys !!!
I need to know how to connect the Haltech wire to my O2 Sensor 4 wire please. The O2 Sensor is the one who is on the Downpipe close of the turbo.
Thanks !!!!
Old Aug 10, 2008 | 09:58 AM
Thedays's Avatar
No people don't no ?
I search on google but I fint nothing for the 02 installation wiring
Old Aug 10, 2008 | 10:52 AM
gxl90rx7's Avatar
destroy, rebuild, repeat
Do you already have a wideband lower down in the downpipe? if your wb controller has a 0-5V output, you could just wire that up to the haltech, and you should be able to do closed loop with it. then you wouldnt need the other o2 sensor
The other option would be to just replace your 4-wire with a stock narrowband o2 (single-wire) and wire it to the haltech o2 sensor input
Old Aug 10, 2008 | 05:39 PM
Thedays's Avatar
cool thx !!!
Old Aug 10, 2008 | 10:56 PM
Thedays's Avatar
Hey hey gxl90rx7 I need you again :P !!
Do you know what is the tachometer wire because my tachometer was **** top when I push the gaz... at 1000rpm it goes to 2500rpm in one shot...
I don't know what is the wire and where it go. I think is go on the Leading and trailing coil ... ?!?!
Thanks a lot for your help !!!
Old Aug 11, 2008 | 10:01 PM
SirCygnus's Avatar
whats going on?
yeah, its on the trailing coil pack.
Old Aug 11, 2008 | 10:31 PM
Thedays's Avatar
Do you know what is the wire ?
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
rotor_veux
Sep 19, 2015 07:13 PM
