Go Back   RX7Club.com > Tech and Performance > Race Car Tech
Old 08-08-08, 09:36 PM   #1
damian
DragonFly
damian's Avatar
Send a message via AIM to damian Send a message via Yahoo to damian
t5 dogbox racing transmission install - video and pics
The stock tranmisson has abeen a weak point in my race car for a while and most full on race transmissions are out of my budget range so I decided to try the relativly affordable t5 gearset option from GForce transmissions.
I picked up a used t5 transmisison, adapter from t5 to rotary bvell housing, and t5 yoke, from Jeff Kiesel. GForce took the transmission and installed their close ratio, straight cut, dog ring gear set.
Here is a link to GFroce t5 info:
http://gforcetransmissions.com/tran_gt-5.asp
With andy helping me with the gear ratios, the 2.46 kit was the best option along with the .82 5th.
Installing the t5 was not that difficult, here are the main issues:
shifter location
the t5 is about 5 to 6 inches more forward so that puts the shifter location in teh dash area, this is a race car so we can just cut the dash up, and I made a shifter extention as a temporary fix to the shifter location. Pics below. Idealy you would use a 'remote shifter' to keep the shift throw the same, similar to this: http://www.steeda.com/products/steed...ax_shifter.php , or you would mod the t5 sililar to this: http://enderw88.wordpress.com/2008/05/03/remote-shifter
t5 trans to rotary bellhousing
not really an issue, just buy an adapter, done. Pics below.
driveshaft
not really a big deal either, a local driveline place made me one in a day, for under $300. Pics below.
supporting the t5 (no ppf anymore)
this was a bit tricky, I made a makeshift bracket/bushing setup to get me by for now, but need to fab up a 'real' brace for the trans eventually. Pics below.
supporting the diff (no ppf anymore)
not a big deal, buy a banzai diff brace, done. Pics below.
note: I put bushing material between the diff brace and car chassy.
clutch disk
the GForce kit uses thier upgraded 26 spline input shaft, and this does not mate with the stock clutch disks, but I contacted ACT and they actually have a disk that is the stock FD diameter but mates to a 26 spline inputshaft. Pic and part number below.
trans sensors
Well, its a race car, so this was not an issue. For a street car you would need to do some work here if you want to keep the speedo, et. But its not a big deal, you get one of these for the speedo and you are done: http://store.summitracing.com/partde...part=dak-sgi-5
Link to the video of my first test of the trans, but sure to have the volume up high, the sound is the best part:
http://www.new.facebook.com/video/vi...?v=63326195166
And the pics:
The clutch disk and delrin rod I picked up to make the new shift handle:
The t5->rotary adpater:
The new drive shaft, next to stock one (stock is on top):
Pic of trans with adapter, shifter, and clutch disk attached:
Pic of shift area and trans tunnel cut:
Pic of t5 mounted and exhaust ipe in place so you can see the clearance:
Pic of the Banzi diff brace being test fit:
(more pics in next post)
Damián Dela Huerta - 1995 MB & 1993 CYM
NASA Midwest - 2005 TTU Champion, 2006 SU Champion, 2007 ST-1 Champion
damian is offline   Reply With Quote
Old 08-08-08, 09:36 PM   #2
damian
DragonFly
damian's Avatar
Series of pics making a new shifter 'boot':
Series of pics making the shifter extention:
Series of pics of the temporary trans brace setup:
Pic of the shifter in place:
Old 08-09-08, 12:31 AM   #3
gracer7-rx7
needs more track time
gracer7-rx7's Avatar
Trader Score: (6)
Congrats on your successful efforts. Looks great
IRP powered - Carlisi Memorial Motor - 99 Twins - V-mount
Tripoint custom valved Konis + Ground Control coilovers etc
FS: used/running Street Ported Motor + lots of other low mileage parts
gracer7-rx7 is offline   Reply With Quote
Old 08-09-08, 12:54 AM   #4
Prometheus
Looking to learn...
Prometheus's Avatar
Love the sound of flat cut gears.
Old screen name: sk8erpunk1983
Prometheus is offline   Reply With Quote
Old 08-09-08, 02:00 AM   #5
damian
DragonFly
damian's Avatar
Old 08-09-08, 03:03 AM   #6
damian
DragonFly
damian's Avatar
GOOGLE video link for those without facebook:
Old 08-09-08, 03:10 AM   #7
David0ff
David0ff's Avatar
omfg ... love the sound
David0ff is offline   Reply With Quote
Old 08-09-08, 06:32 AM   #8
Jaime Enriquez
OLDROTA
Jaime Enriquez's Avatar
Looks and sounds killer! Is is full clutch-usage up and down or can you lift and shift clutchless on upshifts?
'73 Rx2 13B Rotary Engineering Monster SP
'85 GSL 12A Streetport (N.A.S.A. spec)
Jaime Enriquez is offline   Reply With Quote
Old 08-09-08, 09:53 AM   #9
CrackHeadMel
Learned alot | Alot to go
CrackHeadMel's Avatar
Send a message via AIM to CrackHeadMel
Whats the lifespan of a gear set like that? can you get a few seasons out of it before rebuilding it?
and, how much did it all cost when you were done
FULL Bridge Cosmo RE | GT4202 | Wolf3D
CrackHeadMel is offline   Reply With Quote
Old 08-09-08, 11:52 AM   #10
rob81gsl
^^rotard for life^^
rob81gsl's Avatar
digging it man. after talking to you up and the track to all the perks of this tranny im gonna have to save my pennies and get one for the fc!!! how far off you figure gearing would be for those of us that arent running 17's... wondering if the gearset in trans would be correct and might have to adjust ring and pinion ratios to get it correct or what
rob81gsl is offline   Reply With Quote
Old 08-10-08, 08:15 AM   #11
BatmanNZ3
FAST BATTY
Hi Damian,
just a few questions if you dont mind, did you have to alter or modify the input shaft to fitt into the eccentic bearing in engine or not, where did you get the adaptor plate made or where did you purchase it please.
I have checked out the G-Force gearset, not a bad price at all, did you have the 5th gear modification done to your box and did you upgrade the main shaft as listed on the g-force site.
Looks to be smooth and fast shifting, up & down, are you stabbing the clutch on down shift ??.
Cheers
BatmanNZ3 is offline   Reply With Quote
Old 08-10-08, 09:06 AM   #12
enzo250
"el rookie"
enzo250's Avatar
if anyone is interested i have a t5 trans and adapter plate. All you would need is the Gforce gearset. I bought a gforce tranny instead so i no longer need it...
"Need Traction"
enzo250 is offline   Reply With Quote
Old 08-10-08, 11:42 AM   #13
ptrhahn
DoO User
ptrhahn's Avatar
Damian,
What specific shortcomings of the factory gearbox does this overcome? power capacity/durability? Shifting speed? Ratio adjustment?
Peter 93: KDR Streetport w/ all bolt-ons, 365 rwhp @15 psi, GAB/M2 coilovers, StopTech BBK, Raceshop rollbar, Sparco EVO, BBS RGR street wheels, Technomagnesio track wheels.
ptrhahn is online now   Reply With Quote
Old 08-10-08, 01:15 PM   #14
thewird
thewird's Avatar
Send a message via ICQ to thewird Send a message via AIM to thewird Send a message via MSN to thewird Send a message via Yahoo to thewird
Will this fit in a street car without hacking up the interior? (making it look stock) My tranny is starting to make noises after the weekly abuse I give it on the track. This would be an awesome upgrade.
thewird
The perfect race car is the fastest thing on the track and then explodes after crossing the finish line.
Calabogie - 2:23.48 (14 psi, only halfday learning)
Mosport - 1:32.92
Shannonville - 1:58.61 (cold, laggy turbo)
Cayuga - 1:19.54
thewird is offline   Reply With Quote
Old 08-11-08, 12:16 AM   #15
thetech
20B #D096
thetech's Avatar
Great job Damian!
How much did it all set you back? BigAl hooked me up with a guy who sells rebuilt Jerico's from NASCAR cup cars for around $2500-3000 which seemed pretty damn cheap to me, but this looks like a great option too!
06 STi
87 FC
thetech is offline   Reply With Quote
Old 08-11-08, 10:52 AM   #16
Fritz Flynn
All out Track Freak!
Fritz Flynn's Avatar
Trader Score: (65)
After hearing that trans your FD is now officially a RACE CAR NOW I must must slow my heart rate and meditate, I'll be on the track soon, breath in, breath out
Hey Damian,
Seems like a lot of compromising went into the setup. How much did this cost relative to the other options?
Keep a close eye on the diff brace. I bought a car a few years ago w/ a cracked PPF and I think the original owner remedied the crack w/ the brace but the brace broke after only about 250 miles of hard driving.
________________________________
HKS FMIC $800 (retails for 1500)
Fritz Flynn is offline   Reply With Quote
Old 08-11-08, 11:51 AM   #17
RX-Heven
I'll blow it up real good
RX-Heven's Avatar
This car just continually evolves and always impresses.
Great job Damian.
What type of power can this handle?
-Dave
3-Rotor powered RCR SL-C in progress.
91 Widebody Turbo Vert...RIP
RX-Heven is offline   Reply With Quote
Old 08-11-08, 12:27 PM   #18
Banzai-Racing
Rotary Specialists
Banzai-Racing's Avatar
The only remedy for a cracked PPF is a new one, a brace on a broken part is certainly is not the answer. Additionally it could not have been our brace considering we have only had it on the market for a little over a year.
However I would keep an eye on it since it was not designed as a differential support to replace the PPF, it was designed to aid in the stability of the OEM components.
PH: (574) 594-2035
Email:
Check out the
for all your performance parts needs.
Banzai-Racing is offline   Reply With Quote
Old 08-11-08, 03:31 PM   #19
kwerks
Racing Spirit
kwerks's Avatar
Send a message via AIM to kwerks
just Awesome!!!
Congratulations !!!
Understeer is when you hit the wall with the front of the car and
Oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall,
Torque is how far you take the wall with you.
kwerks is offline   Reply With Quote
Old 08-11-08, 07:05 PM   #20
thetech
20B #D096
thetech's Avatar
Originally Posted by ptrhahn View Post
Damian,
All of the above!
06 STi
87 FC
Old 08-11-08, 09:38 PM   #21
CrackHeadMel
Were you able to use the stock pilot barring and bushing? or did you have to go with something aftermarket? Or was the inputshaft possibly modified to accept the stock pilot barring
Old 08-11-08, 11:51 PM   #22
wickedrx7
wickedrx7's Avatar
Trader Score: (6)
That sound so awesome... i love how solid it looks when shifting. Wish my T56 was that solid feeling.
I would strongly recommend looking into a different dif brace. The banzia unit is great but as mentioned, wasn't designed to be used alone. i think there are a few LS1 guys who tried that and ran into problems with just the banzia unit.
I would see if you can get one of these, looks like a pretty solid unit and it is chrome moly.
http://www.v8rx7forum.com/v8-rx7-tec...ace-mount.html
93 RX-7 Touring, LS1 swap, Tein Flex, Pettit BBK, Raceshop Rollbar and lots of other custom parts.
wickedrx7 is offline   Reply With Quote
Old 08-12-08, 12:21 AM   #23
damian
DragonFly
damian's Avatar
wow i need to do soem catchin up on this thread:
non-clutch upshofts, just ease off throttle and shift, easign off throttle will release the dog 'teath' from each other so you can shift, when u are on the gas, they actually pull towards each other
still clutch down shofts, listen to the video, you can hear me heal-toe blip still, but its MUCH faster now, like BOOM, BOOM, BOOM....no waiting on syncros to shift
Old 08-12-08, 12:49 AM   #24
damian
DragonFly
damian's Avatar
Not sure yet, i will find out :-) It is rated for much higher power/tq cars (IE like 500 to 600 rwhp..500 tq cars) so if I 'use' it properly (dont wussy shoft, shift hard and cristp) then I would hope it should last a while. Upgraded straight cut gears, these are very strong, so that should not be an issue, and the t5 case is solid, its probably just a matter of how much i abuse the dogrings and when they will need to be touched up or replaced.
was the most affordable dogbox option i could find, most full dogring kits were in the 6K to 8K range and still used the stock trans case, and ful on race dogboxes can be from 6K to 26K depending on setup. Jerico makes some great dogboxes at relativly affordable prices, but with the gforce t5 setup, you can have a solid dogbox for around 3K depending on what you do. I did no upgrades really, just the base straight cut, dogring, close ratio setup. It already has upgraded everything in terms of gears, input shaft, et, et.
- used t5 case (they are all over, anywhere from $20 at junk yard, to $500 for a 'good' trans, btw you dont need a good trans, just the case, since all internals get replaced by the gforce gearset)
- rotary adapter (not sure exactly?? i got this in a groupo deal from jeff K, with the t5 trans and yoke, maybe $300 to $500)
- new driveshaft ($200 to $300)
- gforce gearset (2600ish if you have your own t5 for them to use)
- some other odds and ends, but that is about it for race car, more if you are tying to make it work with stock speedo, et
well thats a complex question, as it involves your powerband rpm range, et, et. But in anycase, its MUCH better than stock ratios :-) lol
gforce knew exactly what to do wit the input shaft to mate with a rotary engine, and it went in like butter :-) they knew the exact number to machine the input shaft pilot.
as i mentioned above, the adpter plate i got from jeff K with the t5 trans aswell. a few places sell an adapter to a t5, gforce may even make one.
i did not do any other extra upgrades (my car is not making crazy TQ or rwhp), and for fifth gear, i went with the best ratio they had for me, a .82. %th gear could not be dogring from what i was told, so u do have to shift 5th (as you see in the video).
stabbing? i dont stab anything on the car LOL .... its called heal-toe, video of old trans with footwork footage: http://videobookmark.net/www/Windows...-2007_test.wmv
>>Damian,What specific shortcomings of the factory gearbox does this overcome? power capacity/durability? Shifting speed? Ratio adjustment?
specific shortcoming, u alrady said it, the factory gearbox...its the 'specific shortcoming' :-)...., its all the things you just mentioned, I have gone through 4 stock trans in last 3 ro 4 years... mainly sheering 3rd gear teeth off DURIGN DECELERATION...one , me and Andy (1 alp co-pilot) blew up all the syncros on during 1 lap lol...anyway, so its exaclty what you said: power capacity/durability? Shifting speed? Ratio adjustment?....all those things.
with some work you could do it, but would have to modify the t5 shifting mechanism so that its farther back, not a remote shifter, but literally extend the shifter rod to a shifter farther back, then you would not have to cut up the trans tunnle or dash at all.
yes, those are cheap for jericos, but arnt they only 4speed? i get 5 gears, and REVERSE!!!! thank GOD for reverse!!! see above for how much it cost me.
FRITZ!!!! holy shit you need to drive this thing, you would really love it, its literally does transform the car's driving experience from a hopped up street car to a full on race car, its my favorite upgrade :-)
>>This car just continually evolves and always impresses. Great job Damian.
thanks :-) ... and talk to gforce abotu the max power/tq numbers, but they estimate int eh 500 tq range (500 to 600 rwhp ish)... obvisouly for my car this was a large buffer, and that is EXACTLY what I wanted, a nice buffer so the trans is no longer a weak point in the race car.
yes, ill keep a close eye on it, this was really to get it up and running, my plan was to eventually make a new full on support for the diff, possibly tiedinto the rear subframe. I think a big part of any braces craking or failing, is lack of bushings, thus I tend to bushing braces instead of directly connecting them to the chassy. Even a stiff bushign material will absorb some drivetrain shock, and you want it to go in teh bushing, not the parts.rr
>>I would strongly recommend looking into a different dif brace. The banzia unit is great but as mentioned, wasn't designed to be used alone. i think there are a few LS1 guys who tried that and ran into problems with just the banzia unit. I would see if you can get one of these, looks like a pretty solid unit and it is chrome moly.
thanks for the link, i will look into it, it may be an easy solution to hold the diff up :-)
Old 08-12-08, 01:05 AM   #25
IaMtHeRuThLeSs1
I'm awesome!
IaMtHeRuThLeSs1's Avatar
That video is straight sex. Love it.
1990 Rx-7 GTU blaze red (Sold)
SW20 MR2
GSXR 600
Porsche 928 (2)
Jaguar XJ6
BMW Z3
IaMtHeRuThLeSs1 is offline   Reply With Quote
buy, dogbox, force, gears, jeff, jerico, junk, kiesel, racing, sound, t5, tko, transmission, tremec, yard
Dogbox gearing? Xeonith Race Car Tech 4 01-08-08 08:32 AM
Fantastic Dogbox for RX7 twister Rotary Car Performance 182 12-07-06 08:11 PM
My Crooked Willow Racing IC install [pics] CrispyRX7 3rd Generation Specific (1993-2002) 50 06-05-02 08:09 AM
Racing Beat Duct install help!! (pics) Toadman 3rd Generation Specific (1993-2002) 5 10-19-01 04:35 PM
