5th gear synchro is just about dead.
Old May 7, 2002 | 11:22 AM
SaabGuy's Avatar
Im switching to Redlin MT90 this weekend, buying the oil today. Right now I have Redline ATF/Manual fluid in there which worked great in the cold, now its too warm.
Third gear grinds when cold.
I guess 145k miles is pretty good. Still drivin it.
Old May 7, 2002 | 02:00 PM
vaughnc's Avatar
knowledge junkie
seems like all rx-7s grind a bit in 2nd when cold - even if you let the engine warm up.
Old May 7, 2002 | 04:26 PM
Gene's Avatar
10 lb. boost, 5lb. bag
Engine warming up doesn't help, because you have to get the tranny hot, which you do by driving it
Speaking of such things, my tranny is all goofed up too. 5th syncro is GONE, I aboslutely must double clutch on the 4-5 change or it goes grindy grindy. The 1-2 and 2-3 shift don't grind, but if you're on it hard they won't go in, it feels like there is a piece of rubber it's pushing up against (springy) I think my shifter bushings need replacement, tho it might be the whole trans (shudder)
Old May 7, 2002 | 05:07 PM
SaabGuy's Avatar
I actually hear its a pretty common problem, grinding 5th gear. I think Im going to save my $35 bux on the redline and double clutch it. I dought that oil will help it any.
Besides. You never get past 2nd when autocrossing.
Old May 7, 2002 | 07:38 PM
rico05's Avatar
WTB S5 N/A FC
I have never grinded in any gear. Guess I am just lucky!!
MILOS7
Oct 9, 2015 02:19 AM
musker
Oct 1, 2015 05:58 PM
