Rotary Drag Racing The place to post your racing stories and info
how to get boost of the line?
Old Jul 28, 2008 | 03:55 PM
sk8world's Avatar
Chasing numbers
2 step, anti lag..... Whats the set up most are running and pro's and cons?
Old Jul 28, 2008 | 05:04 PM
Jay7 Nyc's Avatar
Which ECU are you using? Some ECU's have 2step, anti lag as an option. If you are using a Apexi PowerFC there is a thread that Viking war hammer responded to about how to properly use a MSD 6AL and 2step module in conjunction with a certain RPM module(Chip). Using this method you will be able to leave the line with boost...
Jay7...
Old Jul 28, 2008 | 05:51 PM
13B-RX3's Avatar
7s before paint!!!
MSD two step here. It will build boost till the wastegate opens.
Old Jul 28, 2008 | 05:55 PM
rotorholic's Avatar
DPG Burnout
I just floor it or the 2 step works well
Old Jul 28, 2008 | 05:58 PM
sk8world's Avatar
Chasing numbers
Thanks guys. Very quick responses. I just want to all in order..
Old Jul 30, 2008 | 12:29 PM
Viking War Hammer's Avatar
*** Bless The USA
I pm'd you my old threads.......... I was actually able to get better 60 foots 1.4x's without using my two step. The two step would just blow my tires away, BUT my susension was setup ALL WRONG.
Old Jul 30, 2008 | 08:06 PM
tdazmansFD's Avatar
Out of the game
Hey Viking, anyway you can point me to these threads?
I run a PFC, datalogit etc.. if it matters
Thank you
Old Jul 30, 2008 | 08:22 PM
*** Bless The USA
Thank you
yep, my journey
https://www.rx7club.com/showthread.p...highlight=step
https://www.rx7club.com/rotary-drag-racing-167/tried-my-2-step-today-have-few-questions-about-what-happened-547699/
https://www.rx7club.com/showthread.p...ighlight=relay
Old Jul 30, 2008 | 08:48 PM
tdazmansFD's Avatar
Out of the game
I thank you Sir!
I'm looking forward to tinkering with my FD again.
Old Jul 30, 2008 | 10:15 PM
Busted7's Avatar
Will work for horsepower
My vote would be anti lag over the two step i was told its easier on the motor.
Old Jul 31, 2008 | 01:16 AM
sk8world's Avatar
Chasing numbers
More info on this Busted! I am unfamiliar with both.
Old Jul 31, 2008 | 09:51 AM
Busted7's Avatar
Steve Kan was the one telling me about it and im not able to give good info on it, maybe some of the tuners on here will chime in.
For my purpose i just launch at 7800 rpms and leave on boost but my turbo is not as large as yours so you probley need something to aid the spool!
Old Aug 1, 2008 | 03:32 PM
tdazmansFD's Avatar
Out of the game
I run a PFC and a Datalogit.
I wonder if it would be possible to Log an engine Rev between say 4k-8k. Then, start removing timing from these Vaccum Cells and keep logging/removing timing from these cells until an acceptable limit is reached.
My thoughts are: to Retard timing in the 5-7k range only. Making it easier to spool a Turbo without bouncing off the limiter. And of course this map only to be used on the Strip. When running down the track, we would only run through this part of the map between shifts, if that. (I'm also assuming that once timing has been Retarded, and the turbo spools, that we would still be running in these vaccum cells?
I don't know, any thoughts? Flamage? lol
Old Aug 2, 2008 | 05:32 PM
sk8world's Avatar
Chasing numbers
So explain to me how the 2 step works? Its cutting off the trailing? Why does this create psi? So I take it you have a switch to turn it on but what happens when you shift the rest of the gears?
dkwasherexd
May 27, 2017 04:51 AM
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
