Haltech bac valve= vacuum leak?
Old Jul 28, 2008 | 02:16 PM
AlexG13B's Avatar
brap brap brap
right now im runnin open greddy compression tube. i have the bac as a pwm 2 disabled. i have a bolt in the rubber hose coming out of it, when i pull out bolt it sucks in air and car stalls. y?
Old Jul 28, 2008 | 09:26 PM
prjct87rx7's Avatar
REST IN PEACE DAVE!!!!!!
you still have a afm?
Old Jul 28, 2008 | 10:05 PM
AlexG13B's Avatar
brap brap brap
no. im running a e6k
Old Jul 30, 2008 | 09:13 AM
88rxn/a's Avatar
tom port.. AKA streetport
i kept mine plugged and turned on the zero throttle MAP....
Old Jul 30, 2008 | 11:32 AM
AlexG13B's Avatar
brap brap brap
i have zero throttlemap on. its idling at bout 850-1000 rpms.
Old Jul 30, 2008 | 11:35 AM
88rxn/a's Avatar
with all lights on, stereo, heater and E-fan it wont stall out....im thinking i just might ditch mine....
Old Jul 31, 2008 | 06:11 AM
RETed's Avatar
I think it depends on how you got the screw adjusted on the BAC valve...
Either that or it's stuck open?
-Ted
Old Jul 31, 2008 | 05:04 PM
AlexG13B's Avatar
brap brap brap
good point TED i never adjusted the screw,
also when i give power to the valve with my power probe i can hear the solenoid inside clicking so i dont think its stuck.
Old Aug 1, 2008 | 06:04 PM
AlexG13B's Avatar
brap brap brap
wow u were right ted, it was open to far i guess. i closed it back up via the screw till it wasnt sucking.
now i open it enough where it does suck alittle bit.
how can i get it to raise my idle bout 1500rpms when cold and drop as it warms up?
Old Aug 1, 2008 | 08:07 PM
RETed's Avatar
Yeah, I've been messing around with my BAC valve and E8 set-up recently, and I've found that you can adjust the screw too far for it to not close all the way. :P
I can't get the E8 to consistently hold idle, and I think it's a problem with the E8 programming at this point.
You just gotta play with all the parameters on the idle control...
Forgot if you had an E8 or E6X?
-Ted
Old Aug 1, 2008 | 08:09 PM
RETed's Avatar
Here's the PDf file from v1.71 that does a good job describing all the parameters...
Hope this helps.
-Ted
File Type: pdf
Old Aug 2, 2008 | 06:29 AM
AlexG13B's Avatar
brap brap brap
im using e6k. should i leave it completely closed or just slightly open?
t-von
Sep 10, 2015 01:56 PM
gabescanlon
Sep 5, 2015 12:04 AM
