Haltech E8 wiring up the coils
Old Jul 24, 2008 | 05:15 AM
teamdod's Avatar
FC3S SENPAI
ok i have a 87 turbo 2 and im having a little problem wiring up the ignition i just cant figure it out does anyone know how too
my E8 came with 4 LS1 coil packs someone help me please!!!!!!!!!!!!!!
Old Aug 18, 2008 | 02:57 PM
HAILERS's Avatar
HAILERS
Wow!!!!! They really rushed to answer you. I'm impressed.
Old Aug 18, 2008 | 04:14 PM
fritts's Avatar
Mad Man
You need to figure out which LSX series coil you have. The truck coils and LS2/6 variations trigger differently than the LT-1/LS-1. There is a thread on LS-X coils in the Haltech forum that I started that should help.
Claudio would you happen to have the LS-1 coil settings you used on the 13B Miata?
Dwell depending on if your direct fire should be around 5-6 MS and 3 MS in batch?
Old Aug 20, 2008 | 05:14 AM
teamdod's Avatar
FC3S SENPAI
thanks guys i found a wireing diagram on the haltech forum.
Old Aug 23, 2008 | 10:35 AM
Claudio RX-7's Avatar
EFI Tech Wannabe
For that 13B powered Miata i used about 5.5 mS and have no problems. Constant Charge and Falling Edge is the norm.
Also, depending on power level, fuel used and spark plugs used, you can actually lower the charge time some what. Realistically the stock 2nd Gen coils are pretty stout for 300-450hp applications, if they are in good condition.
windom
Sep 11, 2015 04:48 AM
SakeBomb Garage
SakeBomb Garage
Sep 4, 2015 05:20 PM
SakeBomb Garage
Vendor Classifieds
Sep 4, 2015 05:19 PM
