is the OMP not working?
Old May 6, 2002 | 08:06 AM
forcefed1's Avatar
I haven't had my car too long. about 1000 miles. I noticed it is not consuming oil like I thought it should.
how much oil do these burn? when should I be needing 1/2 a quart?
previous owner had the engine replace that street ported 6 K ago.
is there a way to tell if the OMP is working? a have a PowerFC if that helps.
thanks
Greg
also untill I get this figured out, Ill premix to be safe. how much premix should I add per tankful?
Old May 6, 2002 | 08:28 AM
forcefed1's Avatar
1/2 a quart every 1200-1500 huh well then maybe it is working. I did an oil change about 750 miles ago and it did burn/leak some since then...
also after doing a search, looks like 10z per gal is recommended with NO OMP
with the OMP working 1/2 OZ per gal.
anyone else know how to tell if the OMp it working or not?
Old May 6, 2002 | 05:43 PM
FD Seeker's Avatar
Rotary Optimist
Originally posted by forcefed1
...after doing a search, looks like 10z per gal is recommended with NO OMP with the OMP working 1/2 OZ per gal.
Where did you find the 10oz recommendation? If possible, can you post a link?
I'm looking for a good qualified suggestion about how to premix with no MOP.
FD7KiD
15
Feb 26, 2021 10:12 PM
86glxNA
Aug 22, 2015 08:54 PM
BLK 93
Aug 19, 2015 03:47 AM
FD7KiD
Aug 17, 2015 11:50 PM
