13b 4 port? pics?
Old May 5, 2002 | 11:17 PM
BadAssRX-7's Avatar
The AUTO DOCTOR
13b 4 port? pics?
ok im looking 4 apic of aSTOCK old school? 4 port lower intake. a friend has a "6 port" and im trying to explan that is not a 6 port, there are no 6 port acuators. not even a spot that ther used to be some. i think this is a old school 4 port 13b. i do know this thing has huge exh. ports and they bont look ported or have the steel inserts.. it doesnt have a knock sencer, but does have the motor mount holes on the center plate. thanks for the help fellow rotor heads
Old May 6, 2002 | 12:32 AM
Directfreak's Avatar
I am a Jeeper Now.
Front plate Mount = 1985 and Older
Center plate mounting = all the 2nd Gen Motors
Rear Plate mounting = 93+ motors
All 2nd Gens were 6 port NA's or 4 Port Turbo.
So, by all reasons just stated, your friend is looking at a 2nd Gen TII shortblock.
More Details HERE:.http://www.winisp.net/gsl-se/intake_manifolds.htm
Let us know the results of your query.
Old May 6, 2002 | 09:50 AM
BadAssRX-7's Avatar
The AUTO DOCTOR
good pics, got them of the outside? the intake he has DOESNT HAVE any kinda 6 port mech. thats what got me...we didt remove the intake, only the upper. thanks
David
Old May 6, 2002 | 10:12 AM
Madman's Avatar
David I think this is what you are looking for... sorry the big pic.
Old May 6, 2002 | 11:58 PM
BadAssRX-7's Avatar
The AUTO DOCTOR
thanks madman but nope, i need the OUTSIDE not the motor side of the intake. see this is driving me NUTS(didnt have far) its a 2 peice man. and its 13b i know but there arent 6 port spots, not ever the intake looks like a 4 port. ... the odd thing is the block had (had) injectors in the center plate, and it has 4 oil metering lines and pump vacume thinggys. but im not sure it they are on the intake and motor or not ill get some pics tomorrow. when did they start making a 2 peice man.? will a t2 lower bolt to a old school 4 port motor?
Old May 7, 2002 | 12:23 AM
moremazda's Avatar
Gone Race'n
Well if the center plate has the motor mounts and the fuel injector bosses, then the whole motor is second gen. You say it's a four port with no knock sensor boss, so you are probably looking at a frankenstien N/A. I bet that the turbo mani will bolt to the early 4-ports. And two peice mani came out with the fuel injection 13b.
whizzybang
Naturally Aspirated Performance Forum
21
Feb 10, 2017 12:08 PM
wallyrx7
Rotary Car Performance
Aug 20, 2015 05:55 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
