Megasquirt no communication with ms2 why???
Old Jul 14, 2008 | 07:17 PM
rotatech7's Avatar
im working on my friends rx7 with a 3.57 ms ,he did all the wiring but now when i get on the laptop i open the program then i go to connet to ecu and it says no connection why?? anybody can give me a lil help please??? o and i tried changing the signal or however is called com1 etc.... but nothing is still no connection please anybody????
Old Jul 14, 2008 | 08:04 PM
2Lucky2tha7's Avatar
Back at it again!!
For starters, check to make sure that all 3 led's are lit up and stay on. Next, if you are using a usb adaptor, make sure that your laptop downloaded the driver for it (mine had to). When you open up megatune, go to configurator and activate ms2 in the pull down "menu". Next, select your code variant in there. Make sure you save it. Close it out, re-open it, then go to communications, then settings. Set the data rate to 115200. Now select com and hit "click to test". Do this for every com link (com 1 - 5 typically), until it says "success!"
Old Jul 14, 2008 | 08:10 PM
Back at it again!!
I almost forgot. If you are using a 9 pin wire from you laptop, you need to go to (in windows): start, control panel, device manager, ports (com and lpt), com 1 (or whatever you have showing up), click on it, click on port settings, now set the bits per second from 9600 to 115200 (make sure you press "ok"). Now as for the data bits, parity, stop bits, and flow control, I can't remember if they need to be altered or not.
Old Jul 15, 2008 | 02:39 PM
Aaron Cake's Avatar
Engine, Not Motor
Are you sure you have the correct COM port set up? That is, are you sure that the 'Squirt is actually connected to COM1?
Using a USB adapter? Built in port? PCMCIA?
Have you gone through the Megatune Configurator and selected your appropriate firmware and other settings?
Old Jul 15, 2008 | 08:26 PM
rotatech7's Avatar
welll
i did all the configuration on the megatune configurator but i think it could be what the other guy is saying but i will try that first because ive tried all the com and non works so im gonna check it out asa i get everything str8 ill let you guys know thanks for the help let me know if there is anything else i should check as in the configuration numbers and stuff thnksss
renjiv2
57
Jan 25, 2024 03:34 AM
