Power FC Non linear Wideband Datalogit Interface
Old Jul 13, 2008 | 03:38 PM
JDMspec's Avatar
How do I make the ZT-2 has with no 0-5 volt linear wideband to work with the datalogit? I can log the A/F ratio on the laptop but I also want it to be log in Datalogit accurately.
Old Jul 13, 2008 | 10:20 PM
cewrx7r1's Avatar
Eye In The Sky
Obtain a "AFR vs Voltage ouput" chart from them, and then calculate/figure a poly that makes it work.
Old Jul 14, 2008 | 08:48 AM
afterburn27's Avatar
Lets Go Hokies!
Download the instructions document for the ZT-2 module, it has an AFR vs. voltage output table. Like Chuck said use the poly function to fit a curve to the provided points. I would only fit the curve to points near the target AFR's, otherwise you will be sacrificing accuracy in that region. Just be aware that you probably will not get a perfect fit everywhere.
BTW, you can send in your unit and have it updated with a linear output. I think it costs around $50.
Old Jul 14, 2008 | 11:12 AM
JDMspec's Avatar
I found the table, but I am not that familiar with MS Excel polynomial graphing for A/B/C values
http://www.zeitronix.com/installatio...structions.pdf
Old Jul 14, 2008 | 02:35 PM
JDMspec's Avatar
I found some values for poly ABC online, but I am not sure if its applicable to all zeitronix box in general.
Old Jul 17, 2008 | 07:50 PM
JDMspec's Avatar
I was able to get the ABC values, and run the wideband,but the numbers are just whole numbers and no decimals like the display on my zeitronix datalog.
Old Jul 18, 2008 | 07:40 PM
cewrx7r1's Avatar
Eye In The Sky
Did you select the number of decimals you wanted under VIEW for MAP WATCH or if using an AFR WATCH? It is your responsibility to set up the DL properly.
First read the manual then play with it.
mulcryant
Oct 4, 2015 12:18 AM
