86 n/a motor idle fluctuating
Old Jul 13, 2008 | 01:31 AM
fcdriftingsd's Avatar
Hello, my name is noel and i had just recently purchase a 86 mazda rx7 n/a..Recently the car is suddenly starting to fluctuate, juke and dies out on me out of nowhere..? I am a honda/acura guy, so rotary is something new to me, but when that usually happens to a honda/acura motor it usually means that there is a leak with a hose or either the TPS sensor is going out. So i dont really know if i can apply the same stuff to a rotary engine. I also notice that the oil meter on the dash is not working out of nowhere, so i'm not sure if the oil meter on the dash has just gone out,or the sensor in the engine bay is just bad or im seriously not getting any oil movement in the motor.. so if anyone can give me tips on where to start that would be really helpful.. thank you
Old Jul 13, 2008 | 02:57 AM
Eple's Avatar
Epilepsy
Sooo, the idle is 'hunting' then stalls? Hunting idle is a common problem, search 'tps adjustment'.
Oil pressure gauge is pretty common to die. I'd get an aftermarket one and ignore the stock, retarded, cousin.
Old Aug 20, 2008 | 09:56 AM
seang's Avatar
if the gauge is below zero then the gauge is bad. mine has the same thing wrong.
Old Aug 20, 2008 | 11:12 AM
HAILERS's Avatar
HAILERS
The wire has fallen off the oil pressure sensor that is located below the oil filter.
Make sure the BAC's elect plug has not fallen off or is just barely on the BAC.
What is the latest maint you've done prior to the stange idle?
Old Aug 20, 2008 | 01:04 PM
SDrotary-FC's Avatar
@ pipnorcali
check for vac. leaks , test the tps and is your 7 blue by chance?
hotshot2014
Jul 18, 2017 02:30 PM
incubuseva
14
Sep 3, 2015 12:37 PM
85TIIDEVIL
Aug 25, 2015 12:09 AM
ncds_fc
Aug 15, 2015 10:06 AM
