Can't pass emissions. CA
Old Jul 12, 2008 | 12:53 PM
rps13x's Avatar
Ok, I bought the car a couple of weeks ago and the owner did not provide a smog certificate. I paid the registration fees without having the smog inspection. And now I can't pass smog. I want to sell the car, is that possible or do i have to do anything else first.
Old Jul 12, 2008 | 01:16 PM
kutukutu1's Avatar
hey man, do as we here in florida did when we had to pass smog, pass the guy some cash and get the smog certificate, thats how we did it here in florida.
Old Jul 12, 2008 | 04:06 PM
j9fd3s's Avatar
Community Builder
passing smog isnt hard at all. tons of threads about it.
Old Jul 12, 2008 | 07:41 PM
Incorigible's Avatar
do u know whats wrong with it???
Old Jul 12, 2008 | 08:02 PM
MidnightOwl's Avatar
2 Rotors, 1 Turbo
Rx-7s are sorta notorious for not passing emissions. The FAQ has some info pertaining to passing and a trick to pass if you are desperate. Perform regular maintenance on it, change the oil, replace filters, plugs, wires, check your cats, make sure you air pump is working, make sure everything is okay, then try the test again. My 240 wouldn't pass emissions, but a full tune up did the trick and it passed by a large margin afterwards.
Old Jul 12, 2008 | 10:09 PM
SDrotary-FC's Avatar
@ pipnorcali
toss a brand new cheapo cat converter in there (drive it around and get it real hot) it should pass
Old Jul 12, 2008 | 10:42 PM
Jaime Enriquez's Avatar
OLDROTA
In Cali, the seller is responsible for smogging the car prior to sale....NO IF'S, AND'S or BUT'S. Get some money from him so you can pass it. Legal or Illegal. It will be at least $200 the "rotary way".
Check the West forum....(wackyracer can lead you to the promise land.)
Old Jul 12, 2008 | 11:07 PM
InsomniacFC's Avatar
Will drive for parts
This will help you get started.
Old Jul 13, 2008 | 02:38 AM
magus2222's Avatar
On the fasttrack!
blah, **** wacky.
Lloyd
Old Jul 13, 2008 | 01:44 PM
ericgrau's Avatar
Clean.
Use the chart sm posted and fix the bad component. Note that none of them are the engine. The notorious problem that rotaries have with passing smog lies between the steering wheel and the driver's seat.
JP's 93 fd
Sep 16, 2015 01:12 PM
