tranny swap? 2nd gen
Old Jul 12, 2008 | 11:13 AM
tomuchboost's Avatar
Newbie
im lokkin at a pretty much free running secong gen rx7 but it has an auto trans=( and i wanted to do a tranny swap and im thinkin this shood be alot harder to do than the other way around do to the cluch pedal and other factors
how much work am i getting my self in to ??
Old Jul 12, 2008 | 11:39 AM
rotaryking28's Avatar
JERZEY'S ROTARY POWER
PR rx-7 tranny swap
your better just buying a manual then tryin to do a tranny swap for a auto. unless you got the time an money to do it then be my guest an do it. me i would just by somethin thats already workin how i want it to be.
Old Jul 12, 2008 | 11:51 AM
Newbie
yea i no wat u mean
the only reason im considering this is becuase the car is only gunna take bout 100 bucks out of my pocket and im not sure if saving all that money is gunna be worth the head ake
but i need the car to be stick
Old Jul 12, 2008 | 12:00 PM
danegerous's Avatar
it go down in the dm
tranny swap in an fc is easy. buy the car, piece together the parts locally which could be done for $200 and bam spend a weekend or a day if you're committed and swap everything over. It's all bolt on, search for a tranny swap write up I know they're on here.
Old Jul 12, 2008 | 12:39 PM
KillaKitiie's Avatar
Bongolio
Then read this:https://www.rx7club.com/2nd-gen-archive-72/complete-automatic-manual-conversion-write-up-201102/
The swap can be done in a couple of days if you have all the part's laying around. You are going to have to custom make a couple of tranny mount's soo you will need a welder! Everything else is pretty much bolt on and straight forward. When i did mine it took me 2 day's to get it all together.
One more thing you will need the speedo gear from your auto tranny to be put into your 5-sp tranny so your speedometer will read correctly.
Good luck.
Old Jul 12, 2008 | 01:03 PM
this is my car i got forsale right now if you lookin on getting a rx-7 stick thats got some tweak to it. http://newjersey.craigslist.org/car/713442393.html
Old Aug 1, 2008 | 01:01 PM
SpikeDerailed's Avatar
This sh*t burns oil!
On the S5's according the the relationship chart in the FSM the inhibitor switch and the EC-AT unit are used in the ECU deciding to open the 6 ports or not. Just simply unplugging the EC-AT unit prevent this condition?
Old Aug 6, 2008 | 12:49 AM
Bump for if anyone knows this.
Old Aug 6, 2008 | 12:55 AM
SouthSideSlider's Avatar
whats a Turbo V?
ok my main things are when removing the top bolt on the tranni bellhousing jack up the back of the tranii its much easyer. Also GET A TRANSMISSION JACK!!!!!!!!!. if you know where a car is that you can get the pedals from your good just buy a new clutch master,lines,and slave its the easyest way you'll replace them eventually anyways. oh and dont forget to unbolt you torque converter. oh and spike my 5th+6th ports till work the ATtoMT conversion didn;t bother them.
Old Aug 6, 2008 | 06:37 PM
kyo787's Avatar
Ass ******
Word of warning
Keep in mind, for some one relatively mechanically inclined with access to apropriate tools this swap is EZ. With poor tools and conditions it is a pain in the *** but still pretty simple. There are enough FC's peppering salvage yards to make all the peices an easy ******, but I do have one warning. Certain VIN S5 autotragics have a different shell. That is to say the physical location of the mount is different. If this car is an S5 ensure it uses the "classic" mount points and not the crappy auto one. Or be advised you may have to have the ability to Fab up a trans mount.
pfsantos
Canadian Forum
Oct 19, 2015 07:04 PM
wcr2k11
20B Forum
Oct 13, 2015 07:23 PM
sleepydogz
Old School and Other Rotary
Oct 4, 2015 03:46 PM
