Long story, quick Q: OMP
Old Jul 10, 2008 | 08:16 PM
sv51macross's Avatar
Repentant Noob
Okay, those who remember may recall I was around here askign about engine smoke and admittedly being a bit of a mosquito. I had concluded Lucy needed a rebuild and resigned myself to not going over 4500rpm. Well, I recently came back from a camping trip and after pulling over to restart the car so the tachometer would reativate, I wanted to check under the hood as I had smelled a whiff of smoke after trying the AC unsucessfully. I opened the hood and was alarmed at the smoke comign off the engine. I had dad cut the engine and found the smoke to be rising out of the exhaust-manifold area. concerned, I looked under the car and found the source, a thin, fresh layer of oil on the underside of the cat/manifold which was burning off slowly.
So, could it be a loose fitting on the metering pump or something else leaking oil?
(BTW, while up in Muskegon I found a long, deserted stretch of fairly smooth roadway. Didn't go over 90 or 6000, and the engine was smooth as butter during and after, as well as any driving done)
thanks.
Old Jul 10, 2008 | 10:21 PM
Icemark's Avatar
possible to be a leak from the MOP gasket/O ring, but probably not
Old Jul 11, 2008 | 01:38 AM
Repentant Noob
is MOP metering oil pump? (confused about acronyms). Thanks for the input.
Old Jul 11, 2008 | 04:57 AM
RETed's Avatar
Oil control o-rings are dead - this is why the engine is smoking in the first place...
Now the engine is spitting enough oil that it's getting into the exhaust system.
This is why you see oil seeping through all the mating flanges of the exhaust.
Check the spark plugs - they should be crusty from trying to burn all the excessive oil.
-Ted
Old Jul 11, 2008 | 10:29 AM
Repentant Noob
Just removed and photo'ed the upper plugs.
Here is the fore plug:
http://i280.photobucket.com/albums/k...acation022.jpg
And here is the aft one:
http://i280.photobucket.com/albums/k...acation023.jpg
I'm not sure how to read plugs; is this crusty?
Old Jul 11, 2008 | 11:11 AM
RETed's Avatar
Wow, spark plugs looks remarkably normal.
Why do you think the engine needs a rebuild from excessive smoke (taken from your original question)?
-Ted
Old Jul 11, 2008 | 11:45 AM
Repentant Noob
Well, the smoke made me think that the oil control rings were bad, and I want to take her to the local track (Ginger Man Raceay) before I go off to College. I always assumed that something evil would happen if I loaded the engine too much with bad internal seals/components. And if it isn't the engine, I want to find the source of the smoke as I don't think that the track officials would appreciate having a four-wheeled smoke generator on the track.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
ZacMan
Sep 19, 2015 09:20 PM
rotor_veux
Sep 3, 2015 07:10 PM
