Pacific Raceways Friday
Old Jul 10, 2008 | 04:06 AM
1Seven4Me's Avatar
I'll be headed to Pacific Raceways this Friday to run the RX (finally!) 7/11/08
if anyone is there, stop by & say hello! .... red 88 FC.
it's an open test&tune, grudge drags & street legals..... come on out!
anyone else plan on going?
Old Jul 10, 2008 | 04:33 AM
TweakGames's Avatar
FD pro licensed driver
Good luck and stay safe!
( I should be sleeping ) O.o
Old Jul 13, 2008 | 03:20 AM
1Seven4Me's Avatar
I was able to make seven passes.
car: 1988 Mazda RX7 SE
Engine: 1999 Chevrolet LS1 5.7L (stock)
transmission: 4L60E (stage 2 Performabuilt), 3500 stall
Tires: Mickey Thompson ET drag 28x9-15, MT ET fronts 25x4.5-15
Mods: T2 diff, 5-lug swap, poly bushings, KYB AGX struts, 150# rear springs, Hurst Quarterstick shifter, shorty headers, X-pipe.
will post up a pic of the timeslip if you'd like later...
the best run, 12.113 @ 112.44, had my worst reaction time... best R/t was .170. I need to work on that.
r/t: .968
60': 1.669
330': 4.961
1/8: 7.725
mph: 88.6
1000': 10.109
1/4: 12.113
mph: 112.44
Old Jul 13, 2008 | 02:31 PM
Upgrayedd's Avatar
Double Dose
The T2 diff holds up to the LS1?! I'm surprised...
Old Jul 13, 2008 | 03:06 PM
1Seven4Me's Avatar
yes, in fact the T2 diff can go up to ~450 hp/tq. some guys are going faster than me with NA diffs(but not many). when I first put the car together, I was launching hard on an NA open diff. it all just depends on how hard you're hitting them, manual transmissions are much harder than autos on diffs, a clutch drop transfers a much greater shock load to the ring/pinion/axles... most likely fail point is the stub shaft, occasionally other points.
Old Jul 13, 2008 | 03:11 PM
Upgrayedd's Avatar
Double Dose
Oh sure, I forgot you were running an auto tranny and that does take a huge load off the diff when launching. That's definitely a respectable e/t without engine mods and using an auto.
Old Jul 13, 2008 | 10:29 PM
TripleJay22's Avatar
yeah that is a good time on the stock motor, im running a close set up, but lt1 instead of ls1 and a 700r4 with full corvette internals and b&m shift kit, but no slicks, just some proxies. but are you going to the track any time soon again?
Old Jul 14, 2008 | 12:49 PM
1Seven4Me's Avatar
I'm not sure when I'll be making it back to run again right now, likely next month sometime.
these are some of the remaining T&T dates @ P.R..... (I really need to work on my R/T's)
Wednesdays- July 31, August 6, 20
Fridays- August 1, 8
Bremerton has T&T on August 8, 15, 22, 23...
Aramir
Oct 18, 2015 02:39 AM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
