s4 LSD into s5???
Old Jul 10, 2008 | 12:50 AM
ZhouNeill's Avatar
s4 LSD into s5???
Hi, I have a 90' gxl n/a, and I was curious if the s4's LSD would fit into the s5 housing, or would I have to swap the whole rear end? I was told it would work but I wanted to ask the experts before I tried anything on my own.
Thanks for reading.
Old Jul 10, 2008 | 10:31 AM
Roen's Avatar
The Silent but Deadly Mod
they would fit the housing, as long as it's NA to NA, or TII to TII.
A Miata Torsen will also fit an NA.
An FD Torsen will also fit a TII.
Old Jul 10, 2008 | 02:10 PM
ZhouNeill's Avatar
Thank you for the reply and info. Well I dont have the money for the tII rear end so I wanted to see if the diff off my n/a s4 would work. Which do you think works better: the miata torsen or the s4?
Old Jul 10, 2008 | 02:12 PM
farberio's Avatar
NASA-MW ST4
I believe the s4 is clutch type, and it really comes down to preference.
Old Jul 10, 2008 | 02:22 PM
Roen's Avatar
depends on what you want to use it for
drag? S4
road course? miata
autox? either will do, as long as you build the clutch diff to a non-aggressive lockup rate.
Josh83rx7
Oct 2, 2015 07:13 AM
Josh83rx7
Sep 24, 2015 11:47 AM
