manual boost controller without vac spider
Old Jul 9, 2008 | 10:13 PM
cheesebox's Avatar
Well, I read up on removing the vacuum spider and saw the bit about removing the boost solenoid, and it was okay as long as you have a boost controller, Well I have a cheap manual turbonetics piece and I am wondering if I am alright with that?
Thanks
Old Jul 10, 2008 | 11:01 AM
cheesebox's Avatar
Bump
Old Jul 10, 2008 | 11:13 AM
RockLobster's Avatar
Let's get silly...
Most any BC will work fine. Just tee it into the line for the bypass valve. That location gives the best control IMO. Also easiest to get to and some of the nipples near the throttle body actually measure pressure upstream of the plates. If you are not farmiliar with the vac system on these cars its easy to connect it to the wrong one and get eratic operation.
Old Jul 10, 2008 | 09:07 PM
cheesebox's Avatar
Anyone have a vac routing diagram, I am trying to get this done but I have 2 flanges on my LIM that arent blocked off and I am not sure what their for, maybe 1/2 inch holes and oval shaped with 2 studs on each. And I have no vac spider, no Solenoid rack and I am trying to route the vacuum lines. I also have aftermarket fuel system and FPR. and no OMP
Thanks
Skeese
65
Mar 28, 2017 03:30 PM
MoTeC
Sep 10, 2015 07:58 PM
