Rear drum to disc brake swap - what about brake bias
Old May 4, 2002 | 01:54 PM
JEB Thornton's Avatar
Today, I picked up a rear end out of an 85 GSL and I want to swap pretty soon. When I add the disc brake rearend I think that I will change my front to rear brake bias.
How much of a change will this be and what is the easiest way to correct this.
I have a proportioning vale that I can add or I can get the master cyclender from the GSL.
Suggestions? Thanks ~ JEB
Old May 4, 2002 | 02:53 PM
inittab's Avatar
I read your email
I'm doing the exact same swap as you. Get yerself a master cylinder from a GSL and you should be good. I don't know how your rear looked but mine terribly rusted. I did a POR-15 paint job on it and now it's looks as good as new.
Old May 4, 2002 | 02:55 PM
inittab's Avatar
I read your email
Before.....
Old May 4, 2002 | 03:00 PM
inittab's Avatar
I read your email
After.......
Old May 4, 2002 | 03:06 PM
inittab's Avatar
I read your email
errr
Old May 4, 2002 | 03:13 PM
Aico's Avatar
Nice red crosses.
Old May 4, 2002 | 03:20 PM
inittab's Avatar
I read your email
Originally posted by Aico
Nice red crosses.
huh?
Old May 4, 2002 | 04:33 PM
Redwood's Avatar
Find Racing
Don't worry Aico, I got it, and it was funny.
Old May 4, 2002 | 06:34 PM
85RX7GS's Avatar
How much did you get that GSL rear for?
Old May 4, 2002 | 06:51 PM
I got this one from a pick-a-part place for $169. I could have just goten the 3rd member for $69. The last one I got from a friend for $150.
Old May 4, 2002 | 09:07 PM
inittab's Avatar
I read your email
Yup, sounds about right, got mine for $150 + tax
Old May 4, 2002 | 10:31 PM
82transam's Avatar
Never Follow
LOL I got it too.
Old May 4, 2002 | 10:43 PM
HOZZMANRX7's Avatar
Driving RX7's since 1979
Exclamation Don't forget the proportion valve!!
If you were swaping'82-82 or earlier, you'd be fine. But '83 and later proportion valve is a different part number between disc and drum.
I think what happened is in 1983 the increased the size of the power assist unit.
Old May 4, 2002 | 11:43 PM
etherhuffer's Avatar
Be sure to use organic pads in the rear, not metal. The squeal from the metal will drive you mad.
astrum
24
Nov 15, 2017 08:44 AM
josef 91 vert
23
Sep 3, 2015 11:20 AM
