Turbo Control solenoid valve..
Old May 4, 2002 | 12:36 PM
Brede's Avatar
Question Turbo Control solenoid valve..
Just broke one of the nipples of my Turbo Control Solenoid.
My problem is that here in Norway it will probably take 2 or 3 weeks to order a new one.
But is it possible to use my EGR solenoid valve to replace the Turbo Control? They seem to be very similar.
I don't have the EGR system on my car so I guess it wouldn't hurt to remove the EGR valve and plug the vacuum hoses.
Or am I wrong??
Old May 4, 2002 | 01:11 PM
c00lduke's Avatar
One thing you could do if they look the same, which i dont know cause i have a 93, is check the part number on them. But really i have no clue since i have never seen an erg solenoid before
Old May 4, 2002 | 03:20 PM
artguy's Avatar
WTB** Very Low Miles 94-95
why dont you order one from a place here and have it overnighted.
j
Old May 9, 2002 | 11:33 AM
TYSON's Avatar
WTF is wrong with it now?
If you mean the turbo control in the solenoid rack, you should be able to substitute the EGR solenoid. In the service manual, they use the same test for all the solenoids in the rack. Therefore, if you move the turbo control hoses to the EGR solenoid, swap the connectors, and plug the EGR hoses, you SHOULD be OK. Not 100% sure.
turbo-minivan
69
Feb 4, 2016 12:29 AM
