looking for 17x10's
looking for 17x10's
im lookin for a set of 17x10 sprox +35mm. i was looking at the 5zigens before, but they are now discontinued. does anyone have any suggestions for different wheels types? i plan on running the stop tech bbk up front so that may be an issue also. i would prefer to keep it kind of light aprox 21 lbs or less and im kinda on a budget i dont have $3500 to spend on wheels. any sugestions would help!
thanks
dan
thanks
dan
On the cheap, there aren't that many (if any) 17x10 wheels. You need to look at:
Enkei
Volks
Work
If you don't have the cash, see what you can find used. Work used to make their 5 spoke Equips in 17x10's. You can sometimes find those used for good prices.
Enkei
Volks
Work
Trending Topics
i was thinking about 255 40 17 tires all around (nto1 nittos) i wanted to keep the same wheel all around so i could rotate them as needed. i know the 17x10 +35mm ofset bring the wheel right flush with the fender. i dont mind rolling the fenders i still have to paint the car. what off set with a 17x9.5 would bring the wheels flush to the fende lip?
the 5zigens arent discontinued. They switched from the original model to the "hot version". I know this for a FACT, because my set is sitting in the garage waiting on my coilovers to show up. Cheers!
BTW: they look fantastic!
the difference is a slight hub redesign, the logo is engraved instead of a chintzy sticker, and...thats all I know, lol.
thanks kenny im gunna give your buddy a call and see if he can get a set for me. did you fit you up at all? and what size tires are you runnng? i was thinkong about running 255 40 17. how much did you the set for w/o tires?
Only thing Enkei might have in stock:
Enkei RPF1:
17x10 +38 5x114.3
SBC Color
THIS WILL BE RIGHT IN THE MIDDLE-ISH OF YOUR BUDGET...... With 4th of JULY Special.
Looks like this:
Enkei RPF1:
17x10 +38 5x114.3
SBC Color
Looks like this:
The issue we're having with 5Zigen FN01RC "Hot Version" are the appropriate offsets for our High offset vehicles.
I've been checking regularly and they seem to only have the lower offset 240SX and 350Z type of fitments. If you got +35's then damns you're lucky guy.
Rishie
Rishie
meximan
Sep 25, 2015 01:39 AM
mrgracer
Nov 25, 2003 05:18 AM
