weber linkage etc
Old Jun 25, 2008 | 10:01 PM
Bass's Avatar
Grey-Bruce Rotorhead
weber linkage etc
I've recently installed a weber 48 ida on my 12A and I've searced and searched for what people have used for a linkage to the OMP. I've found a bunch of linkages on pierce manifolds and was wondering if anybody knows which one will work.
http://www.piercemanifolds.com/linkage.htm
My car goes back on the road next week and this is what's still holding my back.
Also, does anybody know the size of drill bit needed to make the third progression hole?
Any help/ suggestions would be much appreciated.
Old Jun 25, 2008 | 10:05 PM
Siraniko's Avatar
RX for fun
IDA comes in either right or left carb of a VW motor. Which one do you have?
for progression hole, just use the closest size to the original two. I just cant remember if I used an index or number drill.
Old Jun 25, 2008 | 10:08 PM
Bass's Avatar
Here's a pic.
Old Jun 25, 2008 | 11:59 PM
Siraniko's Avatar
RX for fun
thats bottom pull so it can be done. I get a pix on how I did my carbs tomorrow.
FYI:
To identify a top pull IDA, the fuel inlet faces the motor. Unlike bottom pull, the linkage will rotate clockwise (if your facing the carb from front of car) so the omp rod linkage will be facing the header side. Imagine how the OMP rod will look like: a retard. Pix tomorrow will explain it better.
Old Jun 26, 2008 | 12:23 AM
j9fd3s's Avatar
Community Builder
whats everyone doing for the throttle cable bracket?
Old Jun 26, 2008 | 12:54 AM
Bass's Avatar
FYI:
Thanks Wacky
Are you talking about the bell crank?
Old Jun 26, 2008 | 01:00 AM
j9fd3s's Avatar
Community Builder
nope. i'm talking about the part that would hold the end of the sheath of the cable.
Old Jun 26, 2008 | 06:15 AM
Clearkut's Avatar
What could possibly go wr
just started a thread on the 3rd progression hole, still waiting some specific sizes
as for the omp lines you need to tap into the fuel bowl(engine side, and extend your omp tubes to reach the new location), manipulate the old omp linkage to operate(open/close) as it did on the stock nikki carb.(i just went with premix and blocked off the opm).
and for the throttle cable sheath stopper, a bracket needs to be made that will hold it in place, i attached mine to one of the bell housing bolts.
Old Jun 26, 2008 | 07:38 AM
Siraniko's Avatar
RX for fun
few old pix
Attached Thumbnails weber linkage etc-dsc01576.jpg   weber linkage etc-dsc01574.jpg   weber linkage etc-picture-147.jpg   weber linkage etc-picture-143.jpg
Old Jun 30, 2008 | 10:30 AM
broke7's Avatar
here are a few pics of mine
Attached Thumbnails weber linkage etc-100_1165.jpg   weber linkage etc-100_1164.jpg   weber linkage etc-100_1163.jpg   weber linkage etc-100_1162.jpg   weber linkage etc-100_1156.jpg
Old Jun 30, 2008 | 10:36 AM
broke7's Avatar
a few more
Attached Thumbnails weber linkage etc-100_1157.jpg   weber linkage etc-100_1158.jpg   weber linkage etc-100_1159.jpg   weber linkage etc-100_1160.jpg
Coochas
44
Nov 5, 2019 11:08 PM
dona1326cosprings7
Oct 29, 2015 06:47 AM
NLPerformance
Oct 2, 2015 07:11 AM
