Megasquirt having trouble with spark
Old Jun 25, 2008 | 07:55 PM
13bdarren's Avatar
Running v2.2 with extra board on unmodified cas. I can get a tach signal but it seems to be at half speed and with random spark. I have had this setup running on my car last year and it worked ok. But since then I have upgrade code version and redid the wiring harness. I don't think it is a wiring issue. But I might have missed something. I don't remember if there is any other mod needed on the board beside the 3 pull up resistors. Any help would be appreciated. I attached my Msq.
File Type: zip
Old Jun 25, 2008 | 10:18 PM
muythaibxr's Avatar
MegaSquirt Mod
It is possible that if you updated your firmware, you need to manually reset your settings, and export/import your fuel/spark tables.
Ken
Old Jun 26, 2008 | 05:11 AM
13bdarren's Avatar
That would not explain why I can't get spark. It only crank a 100rpm but I know it should be at 200rpm.
Old Jun 27, 2008 | 10:19 AM
muythaibxr's Avatar
MegaSquirt Mod
Actually it would explain it if one of the settings got corrupted. Just try it, if it doesn't work we'll continue from there.
Ken
Old Jun 28, 2008 | 01:32 PM
13bdarren's Avatar
what are the spark setting supposed to be.
trigger angle 65
trigger angle 0
cranking timing trigger return
cranking advance -10
hold ignition 0
spark output inverted NO
fixed angle -10
trim angle 0
Old Jun 30, 2008 | 12:42 PM
muythaibxr's Avatar
MegaSquirt Mod
What about the wheel settings?
trigger teeth?
return teeth?
dual wheel or single with missing?
Ken
Old Jun 30, 2008 | 03:49 PM
13bdarren's Avatar
I am using extra card with stock cas
1379 just like in the faq. I get no tach signal with the other settings.
Old Jul 3, 2008 | 02:57 PM
muythaibxr's Avatar
MegaSquirt Mod
With 1,3,7,9, did you check the timing using a light?
Ken
Old Jul 3, 2008 | 06:12 PM
13bdarren's Avatar
no I can't get any spark that is the problem I get the odd random spark but nothing consitent I was trying to set the timing before I even tried to fire up the engine. Very wierd problem I have given up on it for now till I can fiqure out something I could try.
Old Jul 4, 2008 | 07:42 PM
muythaibxr's Avatar
MegaSquirt Mod
The only thing I can come up with then is that when you redid the wiring, you either created noise that wasn't there before, or you miswired something.
Ken
FC3S Timmy
16
Oct 3, 2015 01:08 AM
Rotafuzz
Sep 30, 2015 09:55 AM
Red-Dragon_Akuma
Sep 28, 2015 06:09 AM
