TDC with unknown flywheel
Old Jun 25, 2008 | 04:20 PM
john smack's Avatar
Ok I am trying to find TDC and I dont have a stock flywheel i found some write ups on finding TDC and found them helpful but is there a diffrence on finding TDC with the counterweight from using the aluminuim flywheel or the lightened steel one.
How can I find out which one I have without removing the engine or tranny?
here are two pics
Attached Thumbnails TDC with unknown flywheel-dsc02472.jpg   TDC with unknown flywheel-dsc02473.jpg
Old Jun 25, 2008 | 05:28 PM
djessence's Avatar
djessence
You could remove the front e-shaft hub, making sure to take the necessary precautions, and align the key to 9 o clock and stick the hub on, then stick the pulley on with the timing marks at 12 o clock.
Old Jun 25, 2008 | 06:08 PM
john smack's Avatar
ok what are the nessesary precautions? I do have a spare 12a to do a practice run on
Old Jun 25, 2008 | 06:11 PM
djessence's Avatar
djessence
Mazdatrix has a faq on the matter. I believe its just wedge something against the clutch so its fully depressed for the duration.
This is to prevent the thrust bearings on the front from falling out of place
djessence's Avatar
djessence
http://mazdatrix.com/faq/pulley.htm
Old Jun 25, 2008 | 06:14 PM
john smack's Avatar
Thanks Man
Old Jun 25, 2008 | 06:17 PM
john smack's Avatar
ok so just hold the pedal down with some wood and pull the fron e shaft bolt then line the keyway mark up with 9'oclock and that will be TDC
Old Jun 25, 2008 | 06:24 PM
djessence's Avatar
djessence
should be close. do you still have the original pulley?
My pulley was 90* off on the hub so if your pulley has timing marks you want the key at 9, the marks at 12 and that will be close to TDC
djessence's Avatar
djessence
https://www.rx7club.com/1st-gen-archive-71/ignition-how-find-tdc-661311/
this talks alot about the flywheel but also mentions the key method
LongDuck
Oct 7, 2015 08:12 PM
GKW
Sep 28, 2015 04:34 PM
