rough idling!!
Old Jun 23, 2008 | 10:11 PM
rota85's Avatar
Newbie
rough idling!!
I have a 1985 gs manual trans. ,154K miles.. it was running great.. a drive the car every other weekend, last saturday a took the ca for a drive for about 40 minutes and average speed of 75 miles/h.. after i exit the freeway the car estar idling very rough, rpm when up to 1500 .. by the time got home the car was almost cutting off....i tri it after the engine was cool.. and is the same situacion.. the rpm goes up nice and easey and no miss firing in the high rpm range.. but its almost cutting of because of the rough idling!...help please!
Old Jun 23, 2008 | 10:40 PM
cdrad51's Avatar
Lorem ipsum dolor sit ame
vac leak, retarded timing, perhaps shutter valve.
Old Jun 23, 2008 | 11:36 PM
blackdeath647's Avatar
weak minds wear the crown
i would start out by checking for vacuum leaks for sure..that'll give you atleast a head start, i'm sure the timing should be fine since you did say it WAS running great until that long drive...
Old Jun 24, 2008 | 05:47 AM
74RX4's Avatar
Round and Round
Be sure to check this hose.
https://www.rx7club.com/1st-generation-specific-1979-1985-18/hose-question-750125/
Old Jun 24, 2008 | 08:19 PM
rota85's Avatar
Newbie
thanks for the pictures (74rx4) and i did not found any leaks in the vac.. hoses that hose is in very good condition. but i pulled out and it cut off the engine right away. and thanks everybody for the help... the car is running great again. a think it was the air vent solenoid.. like a year ago i rebuild the carb when i pulled out it was kind of stuck.. and a think is no to free in the housing( the hole) after i try all the sugestions took the air filter housing and blow some air from the top into the hole that hold the air vent solenoid.. some gas came out to the carb....put everything back star the engine and great.. is back to live..I love it.. againg thanks a lot guys for the help....
kuuva86
Sep 28, 2015 05:42 AM
Jmolina0163
19
Sep 25, 2015 06:06 PM
firzen
Sep 15, 2015 12:04 PM
RotaryBobby
Sep 10, 2015 01:33 PM
