I need help ASAP, I have a meeting to go to, and my car sucks
Old May 3, 2002 | 01:56 PM
Keaponlaffen's Avatar
Unhappy I need help ASAP, I have a meeting to go to, and my car sucks
Hey guys, I'm back with another problem...
Here's the situation:
I drive around for about 15 minutes (car's warm) and then as I go to accelerate out of a turn, the car bogs down, starts doing the wonderful lurch like when you blow a shift going to second, and then it feels like it's running on one rotor... then it dies I let it sit for 10-15 minutes, and it'll start right up, full power, idle nicely, and drive like it's new... then it all starts all over again. I just put this engine in, and I'm using all my old stuff.
The car's a '79 GS with an electronic ignition (the one from the sketch on a napkin) and an '83 12A. No air pump, all vacuum crap removed, no A/C, no vacuum advance. I'm pretty sure it's electrical, but could it be that it's the fuel filter? New coils are damn expensive ($68.03 canadian for one) and I don't have that kind of money.
HELP
Jeff
Old May 3, 2002 | 02:04 PM
79+80_rx-7's Avatar
sounds like fuel pump..... or fuel filter...... go get both... LATERZ
oh, and if you do get a pump, get a universal one...... the cheap kind will work.....
Old May 3, 2002 | 02:13 PM
Universal as in it works in any car? Don't I need to know how many PSI?
Old May 3, 2002 | 02:16 PM
79+80_rx-7's Avatar
well, get one for carburaters..... NOT fuel injection.... shouldnt be any more than $35 US...........
Old May 3, 2002 | 02:24 PM
DONNA's Avatar
i'm with the fuel filter too, had it happen too many times myself, carry a spare at all times, open your old one and see if anything is in it besides gas,,good luck....
jeremy's Avatar
male stripper
i'm running a purolator red from advance auto and the purolator fuel pressure regulator. seems to be doing fine for me right now. it sucks massive rust chunks through the lines and into the filters so it can't be too bad.
Old May 3, 2002 | 02:25 PM
jeremy's Avatar
male stripper
oh yeh, get a purolator filter while your there. they are see through with replacable elements so you can see how dirty the filter really is.
Old May 3, 2002 | 02:27 PM
MyRxBad's Avatar
EliteHardcoreCanuckSquad
Replace the fuel filter.. Shouldn't cost you more then $5 and about 20mins of your time.
Old May 3, 2002 | 02:32 PM
K, will do, off to Crappy tire I go... in my mom's van... hopefully they got one in, otherwise I might hafta go to Lordco... oh well...
Thanks for the input.. Any other ideas, let me now, I'll be back in like an hour to check up, so HELP ME OUT.
Jeff
Old May 4, 2002 | 01:47 AM
K, got a new fuel filter, dizzy cap and dizzy rotor. It didn't work, got a ride to my meeting in my mom's van, and on the way home, I picked up a fuel pump. I noticed while the car is running, the fuel filter (see-through) isn't filling up any more than about 1/8th of the way. This is bad I'm assuming, so I'm thinking that the car is starving for fuel. I'll put the pump in tomorrow and see if that fixes it... hopefully, otherwise it's the coils, or condensors.
Jeff
Old May 4, 2002 | 06:18 AM
DONNA's Avatar
did u open the old filter to look for stuff in it?, u can also check for fuel flow by pulling off the line at carb (nearist windshield) when the car stalls again, should be a good stream comming out, there are two fuel screens in the rails on top of the carb that may be clogged, and there is a metal check valve in the return fuel line next to carb that may need cleaning, be sure to put it back on the same way u took it off ,,,good luck,,hope its not rust in the tank,,,,it wont go away,,,,
Old May 6, 2002 | 12:56 PM
Well, I think I solved my problem, I pulled the line off at the carb the last time it stalled, and there was no fuel. the pump was going good, the filter wasn't even half way full. I pulled the tank, looked at it, and saw that the dent that is in it (from the autowrecker) was right where the pickup line is (like putting your straw right on the bottom of a glass and trying to suck water through). So I think it was sucking enough through to fill the float once, then it was dying from lack of fuel. I pulled out the fuel level float, and popped the dent out. Started it up, drove it around for about 25 minutes (enough to empty the floats for sure) and it seems to be fine. I drove it later. Anyways, back to my Information Technology class, and Visual Basic programming...
Hopefully I solved it, if not, I guess the Rex will be drinking more money this week...
-Jeff
Old May 6, 2002 | 12:59 PM
jeremy's Avatar
male stripper
those bastards. you got lucky. mine is the rust and it is with a vengence. big healthy chunks.
immanuel__7
Canadian Forum
Sep 2, 2015 08:26 AM
ashleymiche
Aug 14, 2015 12:59 PM
